Cheap wilwood dynalite pads?????????
Old 10-22-2006, 09:49 PM
turtlevette
turtlevette's Avatar
St. Jude Donor '03,'11
Default Cheap wilwood dynalite pads?????????
The king of cheap here is having trouble finding "economical" pads for my wilwood calipers.
i've found PFC 80 pads for $34 I'd like to find a cross to some application so i could get lifetime pads at Autozone.
One Great Britain ebay seller advertised dynalite pads as also being Escort pads???
Old 10-24-2006, 04:36 PM
turtlevette
cheap bump
Old 10-24-2006, 05:29 PM
Twin_Turbo
Twin_Turbo's Avatar
no one knows where to buy fuel pump brackets either
try to check if the DLs use the same pad conf. as those old bendix calipers used on most old volvos and fords, maybe it's true.
Old 10-24-2006, 06:40 PM
redvetracr
redvetracr's Avatar
$34...BUY THEM and BE HAPPY.... the pads for the FRONT ONLY on my racer are $175. (and thats a DEAL) when I first started using them they were $205 an axle set.....
...redvetracr
Old 10-24-2006, 06:46 PM
Twin_Turbo
Twin_Turbo's Avatar
check out this price.....
http://www.ptpfab.com/cgi-bin/store/...&P=120-5690-FS
That's for ONE caliper
Old 10-24-2006, 06:50 PM
redvetracr
redvetracr's Avatar
I bet they stop better than a Wilwood Dynalite .....There is an Alcon or Brembo caliper as used on the Weaver tube frame Trans-Am cars that is $2200 each.....
...redvetracr
Old 10-24-2006, 09:39 PM
turtlevette
I guess some think the dynalites are too small for the front of a vette but they are working well enough to stop the turtle. If i ever put more engine in I might need to upgrade but for now i haven't been able to make them fade.
Nice change from getting a mushy and long pedal with stock calipers after 10 minutes of track time.
The only place i was gaining on faster cars at Mosport was the braking zone before turn 5 before the Mario straight. Its sort of a bowl putting serious downforce on the car allowing some real agressive braking.
The big downside is the pad area is much smaller than stock requiring more frequent pad changes.
Old 10-25-2006, 10:05 AM
427V8
C6 the C5 of tomorrow
Support Corvetteforum!
427V8's Avatar
So turtle, How long DO your pads last??
Keith
Old 10-25-2006, 10:13 AM
turtlevette
Keith
about 3 track days and 6 months of normal driving.
i guess that would be about 4 track days or 1 - 2 years normal driving.
Old 10-25-2006, 10:23 PM
turtlevette
i've also hacked up C3 pads and slid them in the dynalites. It works.
Old 10-25-2006, 11:01 PM
84rzv500r
84rzv500r's Avatar
Just curious what kind of lap times do you turn at Mosport with the vette?
I run 1:40 flat @ 90% with my scooter the fast guys on bikes are are running in the mid 1:20's
Turn 1
Turn 2
Old 10-25-2006, 11:20 PM
turtlevette
Turn 1
Turn 2
I don't have a timer. Turn one is a high speed sweeper. A dude in my club went straight on into the inside wall. Turn 2 is an off camber double apex. A bunch of fun. This track is my favorite so far.
Right before turn 5 is where i was gaining on the newer vettes, miatas and pretty much everyone else.
Old 10-28-2006, 04:21 PM
turtlevette
whats a universal brake pad?
The summit site is loaded with them.
Old 10-29-2006, 12:35 AM
ferndog4
ferndog4's Avatar
Turtle,
I found this on the willwood website:
http://brakepads.wilwood.com/04-race/wilwood.html
or if you want to interchange:
http://brakepads.wilwood.com/07-interchanges/index.html
Would be easy if we had an FMSI # which may be stamped on the backing plate of the pad.
Old 11-01-2006, 06:43 PM
turtlevette
thanks ferndog,
bump again for cheap price
Old 11-02-2006, 09:14 AM
0Corvette Engineering
Former Vendor
Corvette Engineering's Avatar
Try calling Behling racing equipment, they usually have pretty dang good pricing...
Old 11-11-2006, 01:54 PM
turtlevette
went ahead and got some gator (bp10 smart pads) from jegs for 41.95 because of free shipping. I needed to have some spares for this weekend.
Does the dynalite use a square o-ring or round? What kit should i order?
To Cheap wilwood dynalite pads?????????
Old 11-11-2006, 04:00 PM
flynhi
flynhi's Avatar
I'm using BP-10s with my new Wilwoods and I like them very much.
Old 11-12-2006, 10:14 AM
427V8
427V8's Avatar
Here's a link to a pdf that has all the part numbers for the caliper
This is the the front calipers
http://www.wilwood.com/PDF/fl99.pdf
this is the rear calipers
http://www.wilwood.com/PDF/fl104.pdf
Old 11-12-2006, 01:04 PM
turtlevette
the Narrow Dynalite is totally different from the dynalite.
You show dynalites for the rear.
The gator brake pad is shown as 150 - 2391K.
The gator pads i bought are 150-8850K.
The dimensions are exactly the same.
There are so many variations of calipers it gets really confusing.
Quick Reply: Cheap wilwood dynalite pads?????????
