Unusual Problem - high RPM Miss in 2nd Gear Only
Unusual Problem with 390 or 410 Gears SOLVED - high RPM miss 2nd gear only
PROBLEM SOLVED THANKS TO NICODEMUS.
SEE POST 8 AND 18 BELOW - MAKE SURE YOUR TUNER KNOWS ABOUT THIS, IT IS NOT OBVIOUS THAT YOU WOULD NEED TO CHANGE ONE CELL IN THIS SMALL TABLE BURIED IN THE PROGRAM.
I have an unusual problem. At 5800 rpm in 2nd gear only, my car has a bad miss - it is way down on power. It feels like it is hitting a rev limiter, but will continue to rev to the 6500 redline. There is no miss in 1st or 3rd or 4th gear at all.
This problem started after I put in 390 gears, headers and an LS2 Edit tune. I had the tune taken out and the stock tune put back in, and it still does it. My tuner said he saw a few misfires on #3 when he scanned it with his Tech 2 but not enough to worry about. And I understand the computer does not scan for misfires over 3000 rpm anyway so it would not find these.
I changed plugs yesterday and tested resistance in all wires, all wires were the same and the plugs were not cracked and looked consistent and properly colored. Unfortunately, the problem is not solved. I was thinking perhaps bad valve spring but that would manifest itself in all gears I would think and this doesn't. Car has only 9000 miles on it.
Any advice from the guru's out there?
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by Zig
did the 'tune' also change the rear end ratrio ? any chance you're hitting the limiter in second due to the new ratios ?
But please keep the ideas coming! Somebody much smarter than me will figure this out I'm sure. That's the power of the Forum I'm counting on!
No, with a manual you don't have to do any adjustment to the speedometer for new gears so nothing done there.
i was referring to the rpm calculations the ecm uses for the rev-limiter.
it was my understanding that even with a manual transmission you would need to make adjustments in the ecm related to gear ratios.
would not the speedometer read the 'incorrect' actual speed if all you did was drop your tire size ? why wouldn't you need to make adjustments accordingly as a result of a gearset change ?
with a different gearset you will hit the limiter much sooner.
with the 'new gears' at what rpm would redline occur in second gear ?
And I've got the factory stock tune back in and it's still doing it, so I've taken the tune out of the equation.
But please keep the ideas coming!...
Hey Zig,
You may have something, I'm don't know much about the actual mechanics of tuning, just what I've read here. The car hits the real rev limiter at 6500 in every gear without exception and the speedometer still works perfectly with or without the tune. The vehicle speed sensor reads off the driveshaft I think. And the real rev limiter on an LS2 is "soft" compared to the LS1, which hits hard when it kicks in. This will be hard to describe - the LS1 goes "baa-baa-baa" against the rev limiter, the LS2 goes "bzzzzzz". In either case the engine does not rev past the limit.
My 2nd gear symptoms sound very similar to the LS1 rev limiter - except it continues to rev. Thus I characterize it as a miss, or perhaps valve float, but if it was valve float it would be every gear (in my experience with older cars). This mystery has quite a few of my local buds stumped! I wanted to get the forum's thoughts before I started replacing parts ***** nilly, like the PCM or taking it into the dealer.
I had the same problem when I had 4.10 gears installed.
http://forums.corvetteforum.com/show....php?t=1384795
There is a table that lets the rev limiter kick in early. I fixed it with HP tuners. I never realy got an answer on what the table was for but the problem is gone.
I am having the same problem (along with some others) after doing 4.10s. But it happens to me in 1st and 2nd. But not in 3rd. If this were the case ^ wouldn't he mod shops now about it?
THANKS!!!
Joe
I have 462.5 RWHP and 4.10's in my 2006. I was told by my tuner Cartek that the motor is reving faster than the stock tach can culculate, therefore, you hit the rev limiter before the tack indicated redline. My 2005 had 3.90's and had the same problem. Install a shift light and your problem will be solved.
i would guess the one included in the hud would lag accordingly ??
I've sent Nicodemus' info to my shop - he was happy to hear this! Remember, these LS2's are still pretty new to being tuned, with some additional complexities compared to the LS1's that have been out there since 1997.
Mine did not have anywhere near that much power at the time and that was not the issue. The sound even sounds different than the rev limiter and the problem was fixed when the value was change in the table. The problem does not happen in first gear. First revs faster than second.
I can't tell you how happy I am if this is the fix. I put in headers, gears, and a tune and only gained .2 and 3 mph due to the requirement of this short shift at 5800. What a huge disappointment. If this works, I really owe you a beer or two!!
Thanks,
Joe
If anyone is getting gears in an 05 they should make sure their tuner knows about this one esoteric change. I doubt anybody touches that table otherwise.
Location: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
