2002 LS6 9,000 Miles
Engine pulled for a stroker. Here is a list of the parts that were removed from the engine to be reused on the new engine.
- Oil Deflector (windage tray)
- Oil Pickup Tube
- 2 Oil Galley Plugs
- 2 Coolant Jacket Plugs
- 2 Bellhousing Pins
- Crank Sensor
- Rear Crank Cover
- Front Coolant Crossover
- Rear Coolant Plugs
- Water pump
- Coil packs
- Fuel rails
- Rocker arms and pedestals
But you do get
Long block
Stock intake and throttle body
Stock clutch and flywheel
Stock exhaust manifolds
Stock injectors
Stock oil pump and timing chain
Spark plug wires
Thermostat
Price is $3,200.00 + s&h for everything. Thanks.
- Oil Pickup Tube
- Crank Sensor
- Rear Crank Cover
- Water pump
- Coil packs
- Fuel rails
But you do get
Long block
Stock injectors
Spark plug wires
Thermostat
Originally Posted by LETHL_ZO6
Any interest in selling just the shortblock?
Hadn't really considered it but I guess it's a possibility depending on what the parts are worth. Pm me & let me know what you are thinking.
