Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
If you like tech.. check this out!
Old 10-03-2006, 05:51 PM
Fast_Toys
Fast_Toys's Avatar
Default If you like tech.. check this out!
Here is an interesting comparison between a Corvette and a Miata at a local autocross event. The Corvette finished .2 seconds ahead of the Miata.
Here is the line taken. Miata in red and corvette in blue:
Here is a graph showing speed of Miata vs. speed of Corvette
Lastly, here is a graph showing lateral g's of both cars. As always, Miata is in red.
Old 10-03-2006, 06:03 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Very cool!!
Randy
Old 10-03-2006, 06:19 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Nice, what system did this?
Old 10-03-2006, 06:31 PM
Slalom4me
Slalom4me's Avatar
Nice work.
I would like to do something similar and place my system in other
cars that attend events I go to - especially in the GT3 that produces
times 9 sec faster than the next closest car (and 13 sec faster than
my '89).
BTW - I thought 'All Corvettes Are Red'
Old 10-03-2006, 06:32 PM
jlucas
jlucas's Avatar
IIRC, he's got a DriftBox.
Old 10-03-2006, 06:37 PM
Slalom4me
Slalom4me's Avatar
Interesting that the Miata's velocity between 2,700-3,100 ft
is decidely higher - perhaps the only area where this occurs.
Lateral loads over the same section are similar.
Fast_Toys
Fast_Toys's Avatar
It's a driftbox. You can do exactly what you wanted and use the tool to compare to other drivers (faster ones!). I found it very enlightening and hope it will improve my driving!
Old 10-03-2006, 06:40 PM
Slalom4me
Slalom4me's Avatar
Looking at the map, it appears the Miata went off course, or at least took
a much more generous line going down from 650 to 300 toward the
finish.
Old 10-03-2006, 07:49 PM
gkmccready
gkmccready's Avatar
How much? From where? How hard is it to use? I dug up info on the DriftBox earlier in the year but put it all aside during the big data acq discussion to see who picked what and how it worked. :-)
Old 10-03-2006, 08:11 PM
Fast_Toys
Fast_Toys's Avatar
It's fairly easy to use. I figured it out in a day. The unit records all the data to a memory card and then you upload into software on your computer to analyze. You can move it from car to car easily too (just a suction cup mount).
Old 10-03-2006, 08:29 PM
jlucas
jlucas's Avatar
$750 driftbox.com or http://www.vboxusa.com/contact.php
My only advice would be to compare your needs and future wants. Other GPS based data aquistion systems (DL1, G2X) have sensor inputs and have more software analysis options for slightly more money. Try the software on all the products your interested in becuase that's where you get the benefit from the data that it collects. If Driftbox suits all your needs and you don't need any inputs, it's compact and highly accurate.
Old 10-03-2006, 09:21 PM
RAFTRACER
RAFTRACER's Avatar
the lateral acceleration data in the above charts looks very "choppy" at sustained cornering loads......Driver induced, or is this normal from this system????
Old 10-03-2006, 09:31 PM
Axelrod
Axelrod's Avatar
In this "speed" graph, it's somewhat evident that the Vette is absolutely crushing the brakes hard. Notice how much slower the Vette is going at full decel. There is a 5mph difference on the slow end of the tight turns!
On the other hand, it really shows that the Vette had all of the power. At the top end of acceleration, the Vette was obviously capable of higher speeds. Look at the 1500' mark in the G-graph as well. Where's there little G-load, the Vette is sailing.
The one thing that is a brutal reality, is that even though the Vette is making more peak speed more of the time... he's not using it smoothly. This is outlined in the G-graph. Both cars are running relatively the same G-forces, but the Miata is running smoother by maintaining higher speeds at the tighter turns. The data don't lie!
Without knowing the end result of the .2 second difference in favor of the Vette, I would've guessed a toss-up between the two, and would've slightly leaned towards the Miata after looking at all of the graphs.
Old 10-03-2006, 09:38 PM
jlucas
jlucas's Avatar
Danny, I think that just depends on what system you are used to looking at and what the default smoothing is set at. Raw accel data is quite "choppy", so whether you have realized it or not smoothing was probably applied. In some software packages, the smoothing value can be set to match your preference. For example....
The images are large so click on them to see the detail differences on the lat accel graph.
0.01sec smoothing:
0.3 sec smoothing:
0.5 sec smoothing:
To If you like tech.. check this out!
Quick Reply: If you like tech.. check this out!
