[Z06] Clutch stuck engaged, will not let go.
my friend's 06 Z06 had its clutch pedal stuck to the floor last night. when he pressed the pedal in, it would not come back up. he worked his foot under the pedal and was able to bring it back up, however, the clutch remained engaged and would not let go.
he shut the car off, was uble to put it in 3rd and wobble home. he is going to call one of the local dealers here to come flat bed it to them.
i will let you guys know what happens. meanwhile, any ideas what could have gone wrong.
one thing i forgot to ask him was how he was driving before the clutch problem. but i think he was simply on his normal drive home
The behavior he noted likely derives from nasty-azzed clutch fluid which was subjected to successive high-rpm shifts. Happens. I'd suggest he inspect the clutch master cylinder reservoir and report what he sees.
Dealer will likely want to follow the Chevy protocol of swapping out all the clutch parts. If/when they do that, he needs to ensure they include a new master cylinder and slave too.
Better still, I'd personally refrain from changing the clutch unless cleaning up the clutch fluid doesn't resolve the issue. I say that because there is always risk of post-install drive-train vibrations.
Ranger
no, he is not a forum member. some pics of his red Z06 are in the pic sticky that i posted way back when i got to test drive it.
he is not a forum type car nut and he is not the type to get his hands dirty checking for clutch problems. i only found out when he asked me where he should have his car serviced.
i know about the pedal stuck on the floor problem but i have never heard of one not letting go. it may be several days before i know what happens but thought to post here to see if anyone else has had this problem.
Mine originally started occasionally sticking to the floor only at high RPMs. I took it in I don't remember how many times with no resolution.
Then one day it just stuck to the floor fully engaged like your friend's did and was never driveable again. They didn't know what was wrong; they replaced the whole clutch system, from cylinders to flywheel to clutch to pressure plate.
Mine was in the VIN range of cars with bad clutches. Chevy assured me over and over before this happened that mine wasn't recalled and that my clutch was fine.
...but then they told me the same about the roof......
Andi
Andi
I experienced the same thing during my week on the Nurburg Ring.....I pumped the clutch pedal a few times and could feel the smell of an overheated clutch.....after this time I had no more problem
Originally Posted by Ranger
Is he a CF member?
Ranger
Ranger
Originally Posted by ALLEYNEC5
I had the same problem with my C5 a few months ago and that is what the dealer did.
Andi
Andi
Same thing happened to a friend of mine who converted his C6 vert into a Z06 complete with LS7. It was all over this forum. In his case, the clutch slave failed. They replaced that part and all was well.
the same problem as in the pedal on the floor thing or the will not disengage part?
guys we need your help once more.
getting ready to take the car to the dealer but the battery is dead and we dont know how to open the door.
i thought there was a lock right above the license plate that can be used to open the hatch like the coupe has. well, there is a hole there on the C6Z but its plugged up with a rubber grommet. pulled the grommet and there was just a hole.
so... anyone know what the procedure is to get the door opened if the battery is dead?
Every C6 has the key hole, it is about 1 1/2 inches to the right of the cutout for the plate light. There is a rubber grommet just right of the keyhole, wonder if you were looking the wrong spot. If not, you are somewhat screwed.... and your friends car has been tampered with...
"If your vehicle has lost battery power, open the
hatch/trunk using the vehicle key. The key lock cylinder
is located on the rear of the hatch/trunk lid above the
license plate. Turn the vehicle key clockwise in the lock."
i wasnt the one to actually look under there. he told me about the problem and i told him where the key hole was. he called me back to tell me that the hole didnt have a lock inside of it. i thought that perhaps for weight savings or whatever reason, the c6z had the lock deleted.
i will tell him to look again but cant figure how he could have missed it if it was there. maybe i have to go over there myself...thanks for the info
no flames please I am just really curious
I am not trying to be negative but simply to ask a question that I think needs asking: Everyone says that the Z06 offers fantastic bang for the buck in super car performance.
My question is how can this be when the car has such an obviously inadequate clutch? Furthermore, as with the C6, is it not poorly engineered as well if it needs the hydraulic fluid changes frequently?
Is the Z06 clutch the same as the C6? If so how could that possibly be? I have had no clutch problems myself but read of plenty in the manual C6 that seem identical to those reported here in the Z06.
I don't get how a car with a clutch that's so inferior can be called a good buy for the money? Actually, such statements seem like a joke when you read of experiences like this one. It's scary when you think about all that power and facing the unpredictable prospect of the clutch sticking in the engaged position.
just my opinions. how are viper clutches by comparison?
Is the Z06 really worth the money people are paying only to have this kind of thing happen?
This problem has nothing to do with overheating the clutch. I had the same thing happen to me. The clutch pedal was stuck to the floor with the clutch still engaged and in gear running... It was as if there was no fluid in the clutch, but it was full. My fluid wasnt nasty dirty, car had just over 1k on it at the time.... It is a bad master cylinder...The dealer replaced the master cylinder and everything was fine. BUT it took them 3 days to figure it out and complete that.. not to mention they kept it longer to glue the roof cause they cant multi task!!! But it is fixed!!!
I had the same problem last night when I went to the strip. I went to do my burnout and when I went to push my clutch in after the burnout it stayed down. I pumped it a few times and it finally represurized. I made the run but you could smell clutch all over the place. I made 3 more runs and you could smell clutch on every run.
