[Z06] 160 Thermostat
Originally Posted by Lankhoss
That has not been my experience. My oil would normally be at 167 degrees before, and would rarely get above 185 after sitting at idle, or doing stop-n-go traffic for an extended amount of time.
I can't remember what my exact coolant temperatures were before, but now my car runs at about 180 degrees while cruising, and 195 while doing stop-n-go. My oil temperature is about the same, although it can get up into the 170's on warm days, and gets as low as 157 on cooler nights. The hottest it ever got was when I was at the track a couple of weekends ago. After about 10 laps, my coolant was at 220 degrees, and the oil was at 230.
All a 160 stat does is stay open more often (generally all the time), but the overall capacity of the cooling system remains the same. Again, once a 160 or 180 stat opens, it's exactly the same cooling system.
It might make some sense for the drag racers out there, who want a few more ponies at launch time. For everyone else, it's pretty irrelevant.
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
From what I have been told, the thermostat shouldn't affect the operating temperature, except when it gets really cold....it may run cooler. However, it will help prevent the car from getting too hot, since the thermostat is opening sooner. It seems to be working, since I was running the car hard out at the track in blistering hot heat....and the coolant never got above 220.
And what I was trying to say about the oil vs. coolant temperature is I have ONLY seen the oil get hotter in EXTREME conditions. But 99% of the time the oil is cooler. I'm not sure if the person that was posting about the oil temperature meant that it gets hotter in extreme conditions only, or during normal operation.
Bill Lofland
This is a reply to 4enjoyn. The dyno test before the additions for rear whell numbers was 450.5 rwhp and 423.4 torque. After the additions: 484.4 rwhp and 466.4 torque.
that has got to be the best bang for the buck mod. i've heard of.
therm. $20, gain 33 and 43, that's less than $1 per rear wheel ft lb. gain.
Again, when a stat is open, it's open and that's it, it's done. The 180 stat will not close again while you're continuously running the car, so it's doing the same thing as the 160--allowing full coolant flow.
I do acknowledge that if you are a drag racer, and per Ranger's advice, you want to keep the car under 200 before you hit the staging area, a 160 stat will give you more time to work with. That seems to be the primary advantage. But, GM wants the LS7 running at about 190-200 optimally. That's better for optimum oil temp (hence better lubrication) and less wear and tear on the engine. That's why they put the 180 in it, so it would get to that temp more quickly.
People make the mistake of thinking that cooler is automatically better. You may get a little extra HP for a short period of time, but there are other issues associated with running cooler. The vast majority of engine wear takes place on start up, and until the oil is up to an optimum temp. The 160 stat causes that process to take longer......not good in my book.
Yes.
160 does not work in my 2007 Z06!
I just installed the 160 stat and it flows to much. The fluid does not stay in Radiator long enough to cool. It stays around 180-185 then once in stop and go traffic it shoots to 199-210 and never goes back down. I even see 216-221 at times. I had it installed at West Coast Corvette and John thinks the problem is as stated above. I am changing it out to a 176 stat to see if it helps? I will update after install on Thursday.
Now if you were to find a higher CFM capacity fan to move more air over the radiator, you might be on to something. Nonetheless, too cool is not good.
I did boost up the fan speeds to 55% at 188.5 degrees. I can still go to 70% at 188.5. What about recovery time? How is it effected with different thermo's? With stock Stat it recovered quickly. Now it seems to not come down once over 200 degrees?
Slim, the type of stat should not affect "recovery time" at all. It sounds like something else is going on? How do you know for sure that changing the fan speed programming had the effect that you think it did in stop and go traffic?
In any event, when the car is moving at a good clip, even the fan is rather irrelevant. Once the oil heats up, it's gonna keep the block temp higher since oil is denser than coolant and takes longer to cool down.
#33
the only way heat is removed from the 'coolant' is by airflow through the radiator.
if all other things are equal, fan operating speed, water pump flow rate, car movement (air movement through radiator), etc. the lower temp therm. will have a longer 'recovery' time.
see my post in the other thread about this subject for more information.
i just didn't want to type it all over again.
http://forums.corvetteforum.com/show...7&postcount=43
http://forums.corvetteforum.com/show...0&postcount=45
#35
Supporting Vendor
St. Jude Donor '09
Originally Posted by buchanan
Yes, they are available through Halltech. I use the 160* thermostat, Halltech Stage 1 Filter/Tune and American Racing Headers. The motor runs cooler, down around 175-180* during normal cruising speeds.
It's All-Good!
It's All-Good!
I also have the first two slots on the fan in my program tuned to 55% fan speed. that is 188.5 degrees and 190.
#37
Originally Posted by 4enjoyn
Foosh
Does the LS7 have a 180 thermostat?
#38
Originally Posted by normlunt
Could someone who has changed stats out of a C6 Z06 look to see what temp the stock thermostat has stamped on it?
#39
Mine says NTCL 86C. any word on the torques specs for theose bolts? Other qquestion is there any particular orientation required for the thermostat..meaning rotion wise, I'm pretty sure I did not put in in updside down
#40
I don't think you're asking this Q: I'm sure you noticed which way the spring / sensor part of the stat was when you removed the original. (It's been a couple of years but I believe that it can only go one way ... the long spring / sensor goes into the block.)
Torque: I don't have a shop manual but maybe someone will come on with that info. Sorry. I think it's around 25 lbs.
Thanks for the temperature info. I'm suprised that it's 86C or 187F. Is your Z an 06?
