[Z06] race seats
race seats
I recently bought a 07 Z06 and could you please tell me where the best place(s) to buy race seats(Recaro or others)?
Also Teamtech harnesses?
Thanks
Thanks
Thanks
Thanks
Do you want race seats or good aftermaket seats??
Here is a hint, Race seats do NOT HAVE LEATHER seating surface.
Sparko makes great seats if you fit in them. You want a seat that is very snugg on your sides and holds you in place.
My thigh and rib supports are very tight so I dont slide sidewaise in the seat what so ever.
Sit in many differnt seats if you can. Try to slide side to side in the seat. If you can slide side to side the seat is way too big.
Good Luck
Team teck contact Gary Hoffman, Hardbar is a forum fender.
Good Luck
I guess that you're just nixing the side airbags. what do you do w/ the sensors for that airbag set when changing seats? Other than the track where does one sit in a variety of seats?
Originally Posted by Frankie2blue
Carravagio has nice seats that seem to cover both worlds. Should have at least been an option IMO on the ZO6.
The lower you can keep the weight the better.
I use an aluminum seat with a think faberic covering. Most comfortbale seat I have ever used. Would I use it as a DD? no but on the track it holds me in tight
Received 3,842 Likes
"Ask Tadge" Producer
jas
YES you put in a race seat, the air bag is disbaled. Make sure you have a 5 or 6 point harness system.
Then we get into the DOT leagality. Harnsess systems are not legeal even though they provide better protection.
I dont like driving with harness on the public roads. you cant turn to look behind you in your blind spots. But on the track I prefer them.
HPDEs require equal restraints for driver and passanger too.
For the reasons you note, I don't think I'd keep the racing seat in all the time. I'm told Gary's rails make it easy to switch the seats - I can't confirm or deny . . .
Another good Sparco seat is the Roadster. An important consideration if you intend to keep the seat in the car is ingress / egress and the side bolsters. The higher bolsters feel great in the twisty stuff but can be a pain around town if you are running errands jumping in/out of the car. The Roadster has a more moderate side bolster than the Evo, but you can also remove its bottom cushion to get the Evo effect for the track.
IIRC, John Caravaggio seats (gorgeous) are re-skinned Sparco Roadsters, Evos, or (with major surgery) Torinos, which recline.
Originally Posted by allanlaw
This seems to be the trend with HPDE events - not all have that rule YET but it seems to be coming.
Allan once you have the HardBar mounted seats in the proper place, they will be in and out in a few mins. The only other challange is to keep the telescop steering wheel in the right place.
YOu can see the HardBar rail mounted on the floor here
Here you can see my RIB supports. ( These have saved my sides and body more then harnesses)
My seat is an Ultra-Sheild Pro Road Race 14" wide
Thank you guys for all the info, I have decided to call Dan at Vetteworksonline. He just started to carry TeamTech, so you can get complete package from him.
Thanks again.
Thanks again.
Aftermarket seats
For what it is worth: I changed out the stock crappy driver's seat for a Euro version Porsche GT3 seat, placed the SharkBar and have a 5 point harness set-up. The change out of the seat will not deactivate the main air bag as long as the connections at the stock belt and underseat wiring harness are intact.
I was at a local Chev. dealership and looked at the display car 06' Cobalt SS; unbelievable... it has recaro seats that are well bolstered. What the heck is wrong with G.M.- they should offer an option for "hi Po " seats.
Former Vendor
I've had two calls from people that have used our seat mounts in 2LZ packaged C6Z and they said that with the stock seat removed and all seat belt and air bag connections unplugged, that it limited their speed. Can anyone confirm? and if so, is there a Plug in fix?
I just picked up a set of these in black cloth last week for my Z: http://www.corbeau.com/products/a4/a4.shtml
Also got the matching rails... Corbeau will factory install a pass-through in the bottom cushion for sub belts for a nominal fee. To my knowledge the A4's are one of the few racing style seats with a recline mechanism which will fit in the C5/C6. Here's a thread with them being installed in a C5: http://forums.corvetteforum.com/showthread.php?t=892767
As far as harness bar and harness goes, I went with the Shark Bar and TeamTech 6-point harnesses. I was originally planning to go with Gary's Hardbar, but determined it might cause a seat travel issue for one of my frequent passengers (who is 6'3"). The Hardbar is a great product (and lighter than the Shark Bar), but I opted for the Shark Bar for the extra clearance. Both Gary from Hardbar and Dan from Vetteworks are awesome to work with! Don't worry Gary, I'll be ordering a brake package from you once the caliper solution is finalized
