Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
Seat up-grade installed (Sparco Roadster)
Old 09-15-2006, 12:33 AM
HeyFred
HeyFred's Avatar
Default Seat up-grade installed (Sparco Roadster)
Finally, I am part of the car.
No more flowndering like like a fish out of water while cornering.
All I can say, this install was a challenge and well worth the time spent to get it right.
The seat is as low as I can get it using these rails
Currently, the seat is tilted 35 Deg and fits me comfortably.
Seat had to be adjustable, because the car is not for track only.
Used Recaro siders vs Sparco.
* With Recaro you have more back and forth adjustability because they are longer than the Sparco rails.
* With Recaro, looking down the center of the inside of the slider, you don't have issues with nut and bolt heads disrupting the sliding action of the rails. Sparco rails are designed to slide differently and looked as if the nut or bolt head may cause issue to slider movement limitation.
Next is the steering wheel upgrade.
The car just keeps getting better and better.
Keith
Old 09-15-2006, 01:09 AM
TakeAwayTheFear
TakeAwayTheFear's Avatar
wow man looks good! what steering wheel you getting?
Old 09-15-2006, 01:13 AM
Oh4GTO
Oh4GTO's Avatar
Looks nice. How comfy is it compared to the stock ones? Also hows the recline angle. Do you feel like your sitting straight up or leaning back or in the middle just right? You plan on changing the passenger as well?
Old 09-15-2006, 01:19 AM
Rick-B
Rick-B's Avatar
Looks goood.
Do you sit lower now? How much?
Thanks for any help. (i'm 6'7" tall and i dont even have a vette yet, but i'm already planning to do a similar seat.)
Rick
Old 09-15-2006, 09:02 AM
bmg
bmg's Avatar
Looks good!
I think Sparco could have put the name on the seats at least two more times lol
Old 09-15-2006, 11:51 AM
cj68
cj68's Avatar
Can you post some more details about the install (especially the challenges and also Recaro part number)? I am thinking about doing a similar set up and would like to retain some adjustability of the seats, since I also drive it on the street (I only do the occasional DE, but the stock seats suck for any kind of track driving).
I assume that the power slider is non functional in your installation? I am on the fence about doing a set up like yours or doing the Caravaggio seats that just bolt up (I like the price of the Roadsters better).
Thanks,
cj
Old 09-15-2006, 12:06 PM
kraemer007
kraemer007's Avatar
I like the bride Stradia. Its a bucket seat that reclines. Its only 26 lbs.
A bit pricey though...
Old 09-15-2006, 12:11 PM
yellow01
yellow01's Avatar
Is the standard belt still usable (i.e. does it pull tight across your lap even with the higher side bolsters?
thanks,
Jon
Old 09-15-2006, 01:49 PM
63Corvette
63Corvette's Avatar
Do you track your car with this seat, with A) just the stock seat belt, or B) with a racing harness? I assume as stated above that the stock seatbelt passes ABOVE the side bolsters?
Thanks
Old 09-15-2006, 02:37 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
Originally Posted by Rick-B
Looks goood.
Rick
pretty much same question ...at 6" 6 i have all sorts of issues with these seats...have allready tried carravagio,and an evo...if i can get the seat down ..i'll want two!!
Old 09-15-2006, 02:40 PM
eaa1964
eaa1964's Avatar
thanks,
Jon
I am interested in knowing this as well. Were you able to mount the stock seatbelt receiving end?
thanks
EAA
Old 09-15-2006, 03:05 PM
HeyFred
HeyFred's Avatar
This steering wheel mount:
http://performance.accuratetechnolog...products_id=89
This steering wheel:
http://www.sparcoracing.com/product....&cat=25&page=1
Or
http://store.racinglab.com/mostwhmco32.html
This is the one in my Mustang and it has a good feel to it.
Once I get the hub mounted, I will go down to my local speed shop, test fit for comfort and best guage vision.
This seat fits me well. I am 5'7", 200lbs. and 35" waist.
The seat that fits me best is the Spaco EVO 2. I have them in my Mustang and they were a challenge to get in the car correctly without the shoulder winglets hitting the door when closed. Had to trim the edge of the winglet so it would not contact the door when closed.
From this learning experience, I was able to select a seat that fit the car and my self that did not require modification to the seat its' self.
Each application is going to be custom fit as to the person.
The seat mounting angle is comfortable for me.
You plan on changing the passenger as well?]
No
1.5" to 2.0"
Was gong to adapt the seat to the power seat base but the seat would be to tall for my liking. I like the low driving position, it helps with how your arms are oreintated to the steering wheel and guage vision.
Yes
Today, I am fabbing the mounting tab for the seatbelt snap.
I have racing belts in my Mustang and they are not user freindly on the street, your locked in. Sometimes you want to lean forward and you can't. I am going to put the stock belt back in.
Roadster: Stock lap I would say would work without routing through belt cutouts.
EVO2: Taller side, I would say you have to route stock belt thru the belt cutouts.
I am going to try with the stock belt first.
Old 09-16-2006, 04:48 PM
Rick-B
Rick-B's Avatar
Thanks for all your help!
RB
Old 09-16-2006, 10:56 PM
HeyFred
HeyFred's Avatar
Mounting the stock C5 buckle to go to the inside of the seat is difficult and not comfortable. So I went on a mission to the local wrecking yard to see what I could find. I won't go into detail, but show the treasures I found to solve my issue.
Use an Exato knife to slice open the seam on the C5 plastic release button cover
Use super glue to assemble cover back onto buckle
You can use these rails instead of the Recaro rails. Dam, I knew I should of went to the wrecking yard and looked before I bought the Recaro rails.
The enthusiast for the enthusiast
HeyFred
Old 09-17-2006, 10:02 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
HeyFred.. nice writeup. FYI tall/big guys these aren't the seats for you. I'm 6'4" 240 w/ a 36" waist. I went up to OG Racing in Northern VA and actually sat in them and felt they were ok. After getting them in the car and driving after 20min I was in hell w/ hip pain.
I ran one event at VIR w/ them and they wern't super comfortable.... again this is all due to my size and being too large for them, not because they're bad seats. I loved them and wished I was a little smaller.
I love your idea on the seat belt buckle... amazing idea. I had the standard one in there and it was very very sandwiched and mae slider action tight.
What bottom mount do you use? I see that you're not using side mounts?
Oh and for the passenger side there's a hump in the floor that the bracket has to clear so that lumina bracket wouldn't work.
With my setup I used the sparco bases which were as low as you could get, sparco sliders, and speedware motorsports side mounts. You are correct on the bolt issues.... I eneded up making many trips to the hardware store to get it all right.
Man they looked cool =(
Old 09-17-2006, 10:04 AM
Cobra4B
Cobra4B's Avatar
Oh and while they do sit lower, they sit upright so tall guys will actually loose a little headroom... at least I did.
Old 09-17-2006, 12:49 PM
HeyFred
HeyFred's Avatar
The seat slides forward and back, used the the Recaro sliders.
In the picture, the seat is all the way forward on the sliders.
HeyFred
To Seat up-grade installed (Sparco Roadster)
Old 09-22-2006, 12:20 PM
kermooni
kermooni's Avatar
Will your seat work with the Hardbar installed? If you do not have one, imagine a 2" pipe going from the shoulder belt mount bolt from one side to the other.
Old 09-22-2006, 12:40 PM
AU N EGL
AU N EGL's Avatar
26 lbs is very heavy. try to get a seat under 15 -18 lbs.
plus any racing seat you really want fixed in place, not to recline or slide.
Old 09-22-2006, 11:48 PM
vettedan
vettedan's Avatar
Keith
Set up above will lose at least 2-3 inches in height and is heavy. In addition, there are no provisions to mount the lap and sub belts. Hardbar manufactures a very versatile seat rail and is designed for Sparco Evo Series Seats, Kirkey and other side mounting seats. Aircraft Quality Materials Easy To Install, Provides anchor points for the lap & sub belts.
Dan
www.vetteworksonline.com
Quick Reply: Seat up-grade installed (Sparco Roadster)
