C5 Forced Induction/Nitrous C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth
I almost got in the 9 sunday with a D1
Old 09-11-2006, 10:53 AM
racerrob333
Support Corvetteforum!
racerrob333's Avatar
Default I almost got in the 9 sunday with a D1
Well I almost got into the 9s. my first run was a 10.06 but i lifted at the end ony traped 130.85 60ft was 1.471 1/8 was a 6.44 at 108.51 but it got loose at the end so got back in line to make another run and they shut the track down for about 2 hours for a wreck well it was dark by this time made another run spun bad 60 ft was a 1.512 1/8 was a 6.463 at 108.43 and the 1/4 at 10.06 at 137.57 then it was time to close the track so I think I will be in the 9s if I go back
Thanks Modern Day Muscle Car
Old 09-11-2006, 10:56 AM
procharged_z06
procharged_z06's Avatar
nice !!!! what set up are you running ?
Warp Factor
Warp Factor's Avatar
Received 1,817 Likes on 1,085 Posts
Didn't any one tell you them centrifugals are no good?
torchvette10
torchvette10's Avatar
Nice!! 9s are on the way
Could you give more specs about your car (motor, tranny, Boost???)
Old 09-11-2006, 10:57 AM
torchvette10
Old 09-11-2006, 11:05 AM
tlaselva
tlaselva's Avatar
Inquiring minds want to know!
Very nice times BTW!
Old 09-11-2006, 11:09 AM
QuickSilver2002
QuickSilver2002's Avatar
One thing I can tell you about his setup by just looking at the results (it is not an m6).
Old 09-11-2006, 11:29 AM
DSOM Z06
DSOM Z06's Avatar
Congrats!! And a convertible no less.
Old 09-11-2006, 11:31 AM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
That is one awesome back to back runs that is for sure and post some info on the setup
Old 09-11-2006, 12:12 PM
mdhmi
mdhmi's Avatar
Great numbers Rob.
Is that a stick or auto car? If it's an auto I'm curious about the convertor size that allows for 1.4 and 1.5 60's.
Stock cube motor?
Old 09-11-2006, 01:15 PM
MIKE-C5
MIKE-C5's Avatar
St. Jude Donor '05-'06-'08
Default Great Job
Congrats....next time line the back tires on the starting line up and you there.......
Old 09-11-2006, 01:38 PM
racerrob333
Here is my set up
forged motor stock cubes
Afr heads 225
mdmc cam
D 1 single innercooler 15 lbs boost
Rosslier tran and yes it a auto not much stall its a real tight convertor
50 shot of nitrous thats what makes my convertor flash
all harden shafts
oh yeah ccw wheel package with 28 in slicks
I got video shot me a email addres and I will send it to ya
Old 09-11-2006, 01:42 PM
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
Originally Posted by racerrob333
Here is my set up
Afr heads 225
mdmc cam
all harden shafts
Rob shoot the video to nick.steffens@usionline.net and I will host it for you if you want.
Good numbers...
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old 09-11-2006, 03:01 PM
4DRUSH
4DRUSH's Avatar
What rear gears gives you a 1.4-1.5 60' with the 28" tires ?
Old 09-11-2006, 03:04 PM
BLOWNZO6
BLOWNZO6's Avatar
Here is the video
http://www.usionline.net/robsteelesept2006.wmv
EDIT... MAN it is a convertible even.. NICE.
Good video.
Old 09-11-2006, 03:15 PM
cablebandit
cablebandit's Avatar
vid doesnt work for me...i get some text gibberish.
Get rossler to send you a t-brake....full electronic shifts...and it will stall big time when the boost hits the converter. Then you keep your tight stall and lose the weight of the spray
Old 09-11-2006, 03:16 PM
BLOWNZO6
BLOWNZO6's Avatar
RIGHT CLICK.. SAVE AS
To I almost got in the 9 sunday with a D1
Old 09-11-2006, 03:18 PM
racerrob333
3.42 gear
Old 09-11-2006, 03:22 PM
racerrob333
Yeah that is the next mony to spend. yeah I cant bring it above 1600 rpm on the brakes it will push threw
Old 09-11-2006, 03:24 PM
racerrob333
Originally Posted by BLOWNZO6
Here is the video
Good video.
Thanks for posting
Quick Reply: I almost got in the 9 sunday with a D1
