Ported LS2 intake by Jeremy
Just got this yesterday from another forum member. I am impressed with the workmanship, all the ports are nice and smooth. It may be a while before I get it installed, but will post dyno numbers when I do.
How can you(I) get one of these?
I got mine off of the C6 Parts for Sale forum, just by keeping my eyes open. CHarissvette (Cory) posts on here quite often. Do a search on his username and then PM him. Jeremy works for one of our supporting vendors, I believe. I'm sure if you do a search on Jeremy Formato, you will be able to find him.
I see you picture of inside the intake, it that the ported intake? because cory's looks like he does alot more work to his intakes
http://www.ls2portworks.com/LS2_Intake.php?aa=0&si0=4
brian
brian
St. Jude Donor '09
brian
brian
Thanks, Brian. I am kind of **** about the quality and the service. My standards are high.
brian
brian
Can't disagree with your general statement, but I would not characterize these mods as "hogging out the ports". Real world results are what count, and both Cory's and Jeremy's ported intakes have shown impressive TQ gains on the dyno.
I've got a Cory ported intake too and I'm sure it has something to do with my 424 RWHP number. The ports aren't hogged out so much, they are moved forward or back depending on which port you look at. I compared Cory's to my stock one when both were off. Looks like a good gasket match port job to me, I'm used to the old school stuff.
But this intake sure is a lot easier to install than the old ones! Just a few minutes. I did a how to post with tips and pics a while back if anyone is interested to search for it.
Originally Posted by tucker0298
hey joe, what mods do you have ? im assuming cam and if so which cam did you go with, 424 hp is nice
http://forums.corvetteforum.com/show....php?t=1495324
brian
brian
I had mine ported, performed the intake swap in 14 minutes while on the dyno, and made another pull while the temps were still up. I had great results! Thanks Cory!
St. Jude Donor '09
Originally Posted by cbrf4i1
hitman, i never stated jeremy's work was "hogging out the ports." i was only referring to 99 torch statement "he does alot more work to his intakes", if that means he would prefer someone just "hooging out the ports" he might not get the result that he hopes for.
brian
brian
Former Vendor
I have a ported formato intake and with my Thunder Racing(TRak Cam) Cam only C6 I am pushing 450rwhp. Jeremy does good work. Why not install the intake yourself, takes less than 1 hour. Took me less time than that by myself.
