Adjusting the replacement SMC roof – DIY w/pics
The recall instructions were revised on Aug 25 to mention that the new SMC painted roof sits LOWER then the original one and needs to be adjusted.
If your dealer neglects to do this or isn’t aware it needs to be done, here’s some DIY instructions explaining how I fixed mine.
Please note, the instructions in the service manual say that you need to remove the visors and headliner to make this adjustment.
My car had enough of a gap in there to adjust the front mount WITHOUT doing this.
Please check your car out and make sure you don’t have to do this the long way without damage.
When I picked up my car after the SMC replacement top was installed the top was noticeably lower in the front.
The very next day I saw posted here that the dealer is supposed to raise the front roof mounting points 1.5mm to 2.0mm to compensate for this.
I didn’t want to take the car back to the body shop so I did it myself.
Here is what I did.
This is the drivers side front roof mount
Notice the adjustment screw if you pull away the headliner piece
It requires a T25 TORX bit
I pulled the headliner back and slipped the screwdriver into place.
Loosened up the two screws and raised the mounting bracket.
Tightened it up and did the passengers side next.
Roof lines up great now.
Sorry for the dust & fingerprints. She needs some detailing attention
Here is what I did.
UCC (01-12-2019)
Fix compatible with transparent top??
I have the same problem with my new SMC top. It sits lower and makes a "styroform blocks rubbing together noise" when driving on rough pavement or bumps. When I lower the window a bit the noise goes away so I believe this fix may help. However I wonder how this will affect the fit of my transparent top. Would be a bitch if adjustment was needed every time the roofs were changed.
Any one have any experience with this yet.
Gary
Gary
Former Vendor
Gary
Gary
I know GM should have gotten this right from the get go, but....
Seems like this would be a good opportunity for someone to make a permanent extension for the transparent top pins to add a little height without having to adjust the roof mount when you wanted to switch tops.
Matt
Matt
I adjusted my C5 (both roofs) and C6 roof slightly lower than the leading edge to eliminate roof creaking and noises. What's the problem with the roof front edge being low?
I'm also wondering about the tranparent top? Is everyone getting new SMC top? I have not put back my painted top ever since I got my transparent top.
Thank you. I was putting this off since I figured removing the windshield header trim and sunvisors was a big job. Nice photos and write up.
I was able to adjust the stricker(s), as per your instructions.
I only have the transparent roof. My original roof cracked about 6 months ago. Ever since I installed the new transparent roof panel, it fits very low on the the W/S header. Also, even though I lubed the weather strips with silicone and I replaced both top pin "guides" as per the bulletin, the roof would still "pop" at the front right side latch area. I thought that maybe since the new roof fits so low, there may be "hard contact" between the roof panel and the W/S header, since i had some "witness marks" in the vinyl W/S header trim near the latch. I hope that raising the W/S header stricker (which allow the roof height to increase) will eliminate the roof poping noise. (No, the roof is not separating).
I do feel it is risky, since the header trim could be easily damaged. Not that a tech at the Chevy store would ever shortcut the procedure in the service manual.
Shawn,
Regardless if there will be issues with the transparent top or not, very nice thought on your part to take the time to show everyone how to make the adjustment on the new tops. Thanks for the effort and the thoughtfulness. Nice job man, great post.
I agree
Originally Posted by 30YR W8T
Shawn,
Sorry I neglected to thank you for the great write up, nice job.
Gary
Originally Posted by Hoonose
Only painted tops are being replaced...
Location: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
SHAWN, S, Great pics and post about adjusting the SMC roof. I have a question though. Do you think that the new roof is supposed to sit lower so that the wind flows over the top windshield lip and doesnt create turbulence against the new roof panel shell? It may be on purpose as another preventative of separation. I recently had my top fly off while driving and the dealer replaced it with a brand new top, frame and all. I noticed the new top sat lower. Do you really think its a good idea to raise it back?
Does this adjustment affect how the lexan top sits? The lexan top is PERFECT while the new SMC top seems a tad lower. If so I wonder what the consequences are when using the lexan top?
Thanks
Tom
Thanks
Tom
ahhhhhhhhhhhh...........good point Shortski but knowing GM as I stated, it may be another preventative measure, Ill align the roof and hope I dont kill anybody with another flying panel on the interstate. Once was one time too many.
Great pictures and awesome instructions...but I can't budge either of the two screws in my driver side bracket...and that is the one that I have to move...any idea of what I could do to help them out a little?
