Adjusting the replacement SMC roof – DIY w/pics
Old 09-02-2006, 11:45 PM
Shawn S
Support Corvetteforum!
Shawn S's Avatar
Default Adjusting the replacement SMC roof – DIY w/pics
The recall instructions were revised on Aug 25 to mention that the new SMC painted roof sits LOWER then the original one and needs to be adjusted.
If your dealer neglects to do this or isn’t aware it needs to be done, here’s some DIY instructions explaining how I fixed mine.
Please note, the instructions in the service manual say that you need to remove the visors and headliner to make this adjustment.
My car had enough of a gap in there to adjust the front mount WITHOUT doing this.
Please check your car out and make sure you don’t have to do this the long way without damage.
When I picked up my car after the SMC replacement top was installed the top was noticeably lower in the front.
The very next day I saw posted here that the dealer is supposed to raise the front roof mounting points 1.5mm to 2.0mm to compensate for this.
I didn’t want to take the car back to the body shop so I did it myself.
Here is what I did.
This is the drivers side front roof mount
Notice the adjustment screw if you pull away the headliner piece
It requires a T25 TORX bit
I pulled the headliner back and slipped the screwdriver into place.
Loosened up the two screws and raised the mounting bracket.
Tightened it up and did the passengers side next.
Roof lines up great now.
Sorry for the dust & fingerprints. She needs some detailing attention
C6Whatever (08-12-2016)
Old 09-02-2006, 11:52 PM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
made it a "sticky"
Old 09-03-2006, 05:19 PM
mfinocc
mfinocc's Avatar
Has anyone tried re-gluing the roof panel themselves? I'm real concerned about the paint matching after the replacement is made. My Chevy dealer just called me to let me know the replacement roof was in. They want me to leave the car so they can make sure the paint matches. They said they have had complaints about paint match on other replacements. Why would that make a difference? Really makes me want to bring the car in. I was thinking about applying a good adhesive myself and just forgetting about the recall. Any advice?
Old 09-03-2006, 06:16 PM
BIGGGIE
BIGGGIE's Avatar
St. Jude Donor '05-'06-'07-'08
It Will Match....If Not have them Redo it...
Old 09-04-2006, 11:08 AM
06corvette
06corvette's Avatar
Thanx.
Nice explaination.
Very Clear and easy.
Old 09-19-2006, 03:10 PM
LS WON
LS WON's Avatar
You mean repaint the whole car?
Old 09-26-2006, 06:59 PM
UDRIVESLOW
UDRIVESLOW's Avatar
*************NO****************
DO NOT INSTALL GLUE.....
BRING IT TO A DEALER ....
HERE IS WHAT WE WILL DO.
REMOVE TOP.
WITH A FEELER GAUGE CHECK FOR GAPS ON THE UNDERSIDE OF THE
TOP.
IF NO GAPS WE WILL INJECT 2 PART EPOXY FOAM..(BAD STUFF)
IT FILLS THE INSIDE OF THE TOP WITH FOAM AND ALSO ADH. THE TOP ON IF THERE IS ANY GLUE SEP.
THE COMPLETE TOP WILL BE REPLACED ONLY IF IT IS SEPERATED.
THEN JUST HOPE THE BODY SHOP THE DEALER HAS PAINTING THE TOPS IS A GOOD ONE...
THEY NORMALY MATCH WELL...ANY WARRANTY QUESTIONS
EMAIL UDRIVESLOW@YAHOO.COM
Old 09-27-2006, 04:50 AM
LS WON
LS WON's Avatar
REMOVE TOP.
TOP.
Old 10-18-2006, 11:05 AM
thesilverfox
3rd Gear
thesilverfox's Avatar
Default Roof replacement window problem
After roof replacement has anyone had a problem with there windows hitting the roof making a loud thump when closed. Dealer has had the car three times and still a problem. Now he wants to remove sun visors to adjust??? what do you think? Thanks for any response. Tom
Old 10-18-2006, 08:24 PM
CRZFINN
CRZFINN's Avatar
Same problem here, haven't had the effort to take it to the dealer yet.
Old 10-19-2006, 11:46 AM
dbradley
dbradley's Avatar
Mine did and I traced it down to a weatherstrip mounting screw. The phillips head was 'bunged' up. I sanded the head smooth, reinstalled, reset window valet and no thump. On mine it was the rear most screw hitting.
Old 10-23-2006, 07:03 PM
CRZFINN
CRZFINN's Avatar
Thanks for the hint!
It was the same problem here. In matter of fact all of them (8) where 'bunged' up. Perfect example of the quality work that they do at the stealership...
Old 11-03-2006, 01:18 AM
blown34
blown34's Avatar
After the adustment is done for the new painted roof, how does the glass roof fit?
Old 02-23-2007, 07:59 PM
elofdahl
elofdahl's Avatar
The SMC on my '07 rides low, especially on the driver side. I was proud of myself after having adjusted it per the above instructions, as the poor fit had been bugging me since the day I first picked up my new car from the dealership. My pleasure turned to dismay the next time I drove the car. Wind noise was then audible at speeds above 50MPH at the roof's left front corner. I readjusted it downwards serveral times, reindexing the windows and test driving after each adjustment. The air leak did not cease completely until the brackets were adjusted back to their original position. I've decided to live with the poor fit in order to avoid the wind noise.
Old 04-10-2007, 08:35 PM
RICH 28
RICH 28's Avatar
Exact same problem here.
Old 04-11-2007, 07:37 AM
boz524
boz524's Avatar
Rich, what dealer are you working with in Orlando?
Old 07-11-2007, 01:45 AM
torquetube
torquetube's Avatar
Default Minor correction
The adjustment screw heads appear to be Torx T27s, not T25s.
Mine were sufficiently tight that using a T25 would have risked rounding them out.
To Adjusting the replacement SMC roof – DIY w/pics
Old 07-17-2007, 07:07 AM
jruss361
jruss361's Avatar
They are T27's and a T25 will round out the sockets.
If you look at the picture in the instructions you can see damage to the socket.
Old 07-20-2007, 07:02 PM
silverbullet04
silverbullet04's Avatar
hey Boz,
Mine goes to Classic Monday morning for the top....It has been popping pretty bad....
Old 08-10-2007, 10:57 PM
opus1111
opus1111's Avatar
My glass squeaked like metal on glass on the driver side w/ window all the way up. Re-indexing the window did not help. Dealer had to take door panel off and adjust window down in the fixture. Problem solved. May be a similar problem to yours.
Quick Reply: Adjusting the replacement SMC roof – DIY w/pics
