Alum Calipers - Experience?
Originally Posted by flynhi
Any experience with
SSBC Force 10
Wilwood SuperLite or DynaLite
Baer
Other?
SSBC Force 10
Baer
Other?
I have wilwoods front and rear with a wilwood master cyclinder...saved a lot of weight, look great and stop the car fine....hope to test them on the track soon.
Got mine from Kieth at Corvette Engineering...great guy..very helpful.
Nick
Nick
Originally Posted by panic
i have wilwood superlite and they couldnt be better and the weight savings against the oem item is unbelievable!!!
...and hidroboost is the second best thing after the wilwood calipers, after you fix them you'll be thinking how could you be without before.
trust me
(and i'm not an idroboost seller or supporter )
trust me
Wildwood master ?
How did the wildwood master fit up? Did Corvette Eng supply that you? Any big benefits over stock? I like the hydroboost, but don't want to pay $$$ or have the hassle plumbing it up.
carbster
carbster
I have SSBC on the front and Wilwood calipers on the rear. Both have worked perfectly for 3 yrs now with no leaks, even after a long winter of storage.
Received 1,874 Likes
2017 C2 of Year Finalist
Don't want to hijack too bad....but.....
C-3Stroker.....How do you like the Cragars? I hadn't noticed the SS engraving before on the newer ones. Do they have regular "ball/seat" for lug nuts or do they use the old unilug slot deal? What size are they? Do they clear without spacers?
I've been feeling real nostalgic for old Cragar look but wasn't too wild about some of their designs up 'till I just saw yours.
JIM
JIM
JIM
JIM
Cool...I'll check them out. I recently saw where Weld was going under...so that may not be a good thing.
I love the way they look....now I want some bad since all those little issues are solved!
JIM
JIM
I have a question regarding a 65. Do the C-3’s have the same caliper clearance issue as the C-2’s? I’m in the process of building a 65 and everyone I know that has a C-2 have the Torq-thrust II’s. I have decided on using the Foose Nitrous (gray) wheels just to be a little different. The problem is the wheels will not clear the stock calipers without spacers. Do the Wilwood calipers correct this clearance issue? If anyone has any pictures of the calipers without the wheels on that would be helpful. Thanks in advance.
Foose Nitrous Wheels
http://www.mhtwheels.com/wheel.cfm?brand=4&cat=113
I haven't put any on the vette yet, But I run Coleman 4 piston alloy calipers on all four corners on my BOSS 302 with outstanding results. Saves a ton of unsprung weight (not even counting the alloy hats and lighter discs) and they lose heat way faster as well. I do run 4" air ducts to the fronts, so that may be a big part of the heat disapation. A big improvement, albeit a bit of a pricey upgrade.
Hans
Hans
C6 the C5 of tomorrow
Yes C3 have the same issues as C2 with disk brakes. They are the same setup.
Corvette Engineerings Laguna kit uses Wilwood Narrow Dynalite calipers which have lots of clearance.
They actually sit below flush as compared to the surface of the hub rather than sticking way out like stock calipers.
They are what's behind the Craigers in C3 Strokers wheels.
Yes, I am associated with Corvette Engineering
Keith
Keith
