Finally replaced the door seals
After dealing with water coming into the cabin, I finally tackled the leaking car issue. They gradually worsened over the years until I couldn't have gotten wetter had I left the windows down while driving in the rain.
I called Gene @ Fred Beans and he set me up with everything I needed. Thankfuly Gene knows Vettes.
I tried to reuse some of the parts on the passenger side but decided to replace everything on the driver side.
I spent to much time trying to clean all the old gunk off the passenger side pieces. Also had a hard time sealing all the leaks after reinstall.
Driver side went much smoother. Still a lot of cleaning off the body, but easy install since all the parts were new.
I didn't replace the doors weather strip since they are still in good shape.
Did several leak checks prior to replacing the interior. I think this is the driest it has been in here since I owned her.
Also found that water was leaking thru the rivets that hold the trunk hinge to the trunk. I am looking for something to seal it up that will also be visually appealing.
Running into similar issue
I have a 2000 coupe. Water was first coming in from below the passenger speaker. Think it is seal to the roof/hardtop. I am interested in what you wrote about the rivets.
Then I started to notice water leaking on the drivers seat. Yesterday it poored and I got a good amount of water along the drivers door roof liner. And back towards the speaker. I have to take it in somewhere but I am trying to understand what the issue is so I do not get hosed at the shop.
I was thinking of writing later when I get into it.
Please send me any info/tips: lawrencehays@gmail.com
Received 19,447 Likes
'20-'21-'22-'23-'24
Looks like it was quite a job. Glad you got most of the water stopped.
