Will 18x10 rear wheels work with a big brake kit??
Some of you may have seen my BBS Wheels for sale thread. A question has come up that I can't answer.... can the 18x10 wheels be used with a big brake kit?? Here is the link in my thread. Appreciate your help............
thanks,http://forums.corvetteforum.com/show....php?t=1427983
MIKE
MIKE
Originally Posted by vetterdstr
Big brakes wont work with those wheels.
VR
VR
Would a 3/8" spacer work to accomodate the brakes?
No, big brake systems require many inches of clearance beyond the OE calipers. Those wheels barely clear the stock calipers as it is now.
VR
VR
Try SSBC's 3 piston floating calipers that are a direct bolt-in for the 2 piston stock calipers. They do not "bulge out" like opposed piston calipers, so they don't intefere with the wheel spokes. They are percentage wise a bit heavier than the stock PBR's, but this makes them stiffer, which is important in brake caliper performance. If anyone needs to space their wheels out 3/8" or more, then the studs need to be replaced by longer ones. Studs should be relatively inexpensive to buy, put would take a bit of labor to install. Once you get your wheel spaced outward, then you have to make sure the tread is covered by the fenders.
will depend on the kit/caliper but probably need a spacer. You may be able to get a brake caliper template depending on the type.
MIKE
MIKE
Most race cars yse those 18" bbs, and see what they are packin in there.
DoC
