Custom intake airbridge, DIY
There was a thread started by spinmonster on why nobody had started making airbridges for the C6 like they had for every other car ever make (corvette and otherwise) after 3 years in the model run.
I had actually been thinking the same thing and his thread prompted me to do something about it. Someone here had posted the link to this company a few months ago http://www.hightempsilicone.com
I checked out thier website and after some measurements from spin on the Outside diameter of the MAF and TB (and some of my own for my vararam) I placed an order for half a dozen different reducers and couplers from them. I bought the 4 ply silicone as its heat and chemical resistant upto 500 degrees.
What I ended up using (and reccomend if you have a vararam with TB spacer) is 2 of the 3.5 - 4" transition reducer. One thing I like is they make them in 3 colors. Black, blue and red.
Removing the old ducting was a snap and you just pull out the hookup for the air temp sensor with a pair of pliers. I then drilled a hole in the outside of one of the couplers and inserted it after cleaning it up well.
One problem I ran into was that the couplers were either 1/8" to big or 1/8" to small for exactly what I needed. So taking the advice from a rep at high temp silicone I ordered them 1/8" small and boiled them to soften them up and installed them instantly. Took some elbow grease but the seal is perfect.
Well enough of that here are some pictures....
Been running this for over 3 weeks now and had it tuned this way about 2 weeks ago. No problems what so ever, no CEL.
I paid 26.75 for each of the blue reducers I ended up using. They had clamps for sale to but they were very expensive and I picked up 4 for 5 bucks at the local walmart.
Originally Posted by StrayDog
ABOMINATION.........Nice photos , love the stripes .........
I will order the same as you suggested as I also have the Vararam with the spacer and the stock parts look like crap with that set-up!
Hey Dave - Thanks for the research and the great review. Maybe you could clarify a couple of points.
I see you have the spacer from Vararam. I too, have been enjoying their CAI, but without the spacer. Will I end up a little short on plumbing without the spacer? Maybe now is the time to go ahead and add it.
Is it the Vararam neck that is the most oversized for 4"? It doesn't appear TB end will be too bad.
Also, I need to tap in a 1/8" hole somewhere between MAF and TB for Alky inj. nozzle. Think there's enough tail on the MAF or front of TB assy.?
FWIW: I have used those bar type clamps they show, and have found them to be worth the $, when you have critical joints to seal.
Thanks again, Dick
Thanks again, Dick
Sorry I didn't reply sooner but I didn't even see the posts. Thanks for all the compliments about the car itself, they are not painted on they are vinyl. Nobody can tell unless you actually touch the car though. Lets me change my mind if I want.
The paint on the vararam is touch up paint I bought in 2 rattle cans matching the exterior of the car. I used plastic prep and then primer then 2-3 coats of blue. Yes I painted the top and bottom.
No I wasn't at Carlisle but thanks for the compliment.
Yes, without the spacer you would be short. It needs to be added or a similar one for this to work. Yeah, the vararam size is over sized, the TB side slips on very easy. I doubt you would have a problem for the alk injector. I would tap the TB itself and put it there (in the rear of course). As for the clamps. I purchased them but the looked funny installed and had very little room for error on sizing up or down. In the end I used good old dryer duct clamps and they have been on for 3 months now without budging and inch.
Thanks for all the replies.
