[Z06] Halltech foam filter dyno results
Well I finally had my car dynoed again today after I put in the foam filter from Halltech. I knew it was stronger and I was right. With absolutey no tuning changes at all it made 14.5hp more and 4 ft lbs more in 5 degree hotter weather. 105 degrees in the garage. Not too bad.
before
after
before
after
What mods before? A/F ratio looks spot on. Did LG tune it before for you? I'm just wondering because I have had mine tuned but not dyno'd yet. And all you did was put in Jim's race filter (or street filter)?
Originally Posted by C5 Frank
Looks like a nice gain. What was your 1st mod to go from the 448 to 468?
Originally Posted by Zlicious
with no tuning at all?? Whoa..
Originally Posted by 355Spider
Let the engine cool down. That was just a hot run the first time I ran it when I got to the shop.
Wow 20hp and 30+tq for a cool down on a NA motor!!! Didnt think it made that much difference. Is the filter a factory replacement, or does it require its own set up? Thanks!!
too hard to call without the before/after same day, same conditions...and then overlayed for perfect comparison. peaks are definitely higher.
either way, I bet it's a rocket! I'm going to probably go with that filter....maybe group purchase time?? hehe
Originally Posted by LS WON
Want the power at low RPM's.
You won't notice a difference unless you take it up to 7,000 RPMs.
Originally Posted by jbp8653
I didn't find this to be true on mine. Seat of the pants is noticeable right from the get go.Talked to Jim Hall about the oiling. He said to do it at every oil change. Shouldn't be to much of a inconvience.
I dyno'd both stock and F-1 and saw results about 10rwhp gain(same day).
SOTP was very noticable
jbp8653,
I have no headers only tune (which can be improved I'm told), F-1 filter, and CAI for 476rwhp. I am sure I will see 480 plus with better tune.
I believe that the Air-Charger CAI is a big help in SOTP feel, but how do you measure the increase? Lap times or drag times??? whom has the time and skill do this.
