Help!!!no dashlight, no rear light, no side markers
Cruising
Hi,
Yesterday during driving my dash light, my rear light and the sidemarkers light were out of order, it was dark, but the headlight (high and low beam), indicators, brakelight, radio, courtesy lamp, back up light and everthing else were working. After stoping I checked the fuses, everything ok. Suddenly everthing worked right again, afterwards not, ...
My first suggestion ist the headlight switch.
What do you say?
Thanks
George
What do you say?
Thanks
George
Location: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by reredol
Hi,
What do you say?
Thanks
George
What do you say?
Thanks
George
I ordered the switch from Corvette central today, will change out this weekend.
If for some reason this is not the problem, Ill be doing the whole under dash harness. Ive learned the hard way that when a 38 year old harness starts blowing fuses, you can either
1. spend hours fixign the problem to have another pop up later and another and another
or
2. replace the whole works and be good for another 20 years
cheers
tim
Cruising
I checked the connection to the headlight switch. The connector was not fully plugged to the headlight switch.
So I used a tie strap to fix the connector to the switch.
Everything work fine again.
The connector and the switch as well as the wires look goog, so no need the change the switch.
