Any one using solid body mounts.
Solid body mounts are common with other types of cars. i am considering making some to use with my Pro Street 75. Anyone out there running with them. I just worry a bit since we use a fiberglass body.
Thanks
Greg
Thanks
Greg
Earlier C3's like 68 & 69 used solid mounts...you should be just fine to fabricate some for your car. The early C3's used aluminum "pucks" & shims. Later C3's used rubber cushions which are slightly taller than the solid mounts. Match your mounts to match the compressed height of the rubber mounts.
Cheers,
Joe
Cheers,
Joe
