Redline Water Wetter, IT WORKS!
I added some Redline Water Wetter after my TT install and it dropped a good 9 + degrees!!! I was seeing 208-212 or so while cruizing in 95 degree weather now I'm at 199-201. Not bad for $7.00
Put two bottles in - I saw an additional drop in temp.
Originally Posted by cthusker
What was the temp after 2 bottles? Did you drain some coolant out before adding the waterwetter product?
Yes, I removed coolant before adding the Water Wetter.
Now for racing maybe the wetter is a good thing.
Originally Posted by Hoonose
Lowering the temp isn't necessarily needed or even a good thing. The motor is designed to run at specific temps. I never had any trouble in all my years driving in AZ high temps. It's routinely 110 and above here all summer long.
I also suspect it will also slightly drop you oil temp! GM can tell me all they want about oil temps are ok up to 315 degs but I'm not buying it. Without syn oil you would be in big trouble running at those temps!! I think more good things happen with cooler engine temp than bad. I'm not talking about running at 160 or something like that... I figure 190 to 200 degs is hot enough IMO.
TEN7 (08-02-2020)
Originally Posted by CMEPASU
Do you add the water wetter to the overflow tank or remove the radiator cap?
I know there is a lot more torque available when my engine is around 200 versus 215-220. I simply don't like to see the temp that high because it puts a lot of extra strain on hoses, head gaskets, etc. I suspect the high temp is because of polution control not because it makes your engine run better. Cooler engine = more HP and torque....
And yes it sounds nice to be cooler, but fuel economy/efficiency may drop. And let me say this: In 6 years all the rubber and hoses under my C5's hood were all still as new as I could tell. That includes 6 of the hottest AZ summers!
What you say sounds sensible, but I'm still not so sure that it's really important. I know that dragsters like to get racing before they heat up too much, but I'd doubt there would be any seat-of-the-pants difference with our cars. Maybe the dyno guys could clue us in on typical HP losses with heating up.
When I did my baseline dyno I gained about 20 HP from 210-192
Now one needs to run before and after with the wetter...
just my .02 cents
I added to the tank. Are you back in vegas? If I ever grew some ***** I'd move out there, I love Vegas! Hows the car? Need new tires yet?
I'm not doing tires until I do the rear end. I've got to take some picks and post a new thread here soon...Just got back from the Chevy dealership, added to the LS2 stable and picked up a Trailblazer SS for the wife...Man, that's a sweet truck.
Later, thanks for the info on the water wetter, I'll be doing that next.
Gary
In my C5 I used a 160 Tstat and lowered fans so I could launch at 180. That was optimum for me. Compared to launching over 210 or so you could save a maybe half a tenth at the most with a LS1. I am planning to do the same with the LS2 after I do a test and tune night to figure out my best launch temp.
I am hoping to get some baseline stock runs in next week, then the mods start.
