NAPA Rotors
St. Jude Donor '05-'08
NAPA Rotors
After seeing my first crack rotor this weekend (thanks Jim for cracking one for me ) I decided to buy a set of NAPA rotors as a spare set just in case.
Is the information below corect?
- 86700 front right rotor 18 lb, 14 oz
- 86701 front left rotor 18 lb, 10 oz
- 86702 rear left rotor 14 lb
- 86703 rear right rotor 14 lb, 4 oz
Part numbers are right, but the actuall weight is 17 lbs for each front and 11 lbs for each rear, or my scale is off.
maybe you are now fatter than you thought
thanks
Originally Posted by gkmccready
That's what I have sitting in my living room for later today or tomorrow morning. :-)
thanks -
My main concen was making sure that I dont mess up with left/right.
Is there a way to tell the difference by just looking at them?
glen
Supporting Tuner
Those are the part numbers I bought, Bob
Originally Posted by wtknght1
Rockauto.com
$100 will deliver a full set to your door!
Sorry for being a newb.
Dave G.
Here's a tip for to help with the rusting on the NAPA hats. At the track, who cares, but some of us drive these cars on the street and don't want the nasty rusted look of the hats especially through C5 rims that show everything.
Lighty rough up the hats with some sand paper, tape around the edges of the hat and use 2-3 coats of high temp brake paint or grill paint. Both work fine and there are many colors to choose from. I go with simple gloss black and from a distance they look like 2 peice rotors. Anyway, this will keep the hats from getting completly rusted and looking like total garbage when you drive your car around town.
Usually I am not one for cosmetics, but this is easy, fast, cheap, and greatly improves the look of rotor.
Originally Posted by talon95
Which brand from this site though? I don't see the part #'s listed above.
Dave G.
Dave G.
In the end though, they are all the same...last the same amount of time...same weight, size, etc. The only real difference is the price!
Dave G.
Dave G.
Rockauto.com
part numbers just replace the first 8 with a 5
1. 56700 front right rotor
2. 56701 front left rotor
3. 56702 rear left rotor
4. 56703 rear right rotor
Rockauto.com
Anybody have a current rockauto discount code? It seems like only a few months ago I bought 4 sets......
Rockauto.com
PS> No Johny Walker comments.
Received 8,928 Likes
When you purchase the NAPA rotors double check the pieces in the box before you leave the store. One time I found they put the wrong rotor in the box. The store guys will not be able to tell since all they know are the part numbers on the box and there is nothing on the rotor to indicate the P/N.
Bill
Bill
