Keyless Entry Always Needs to be Reset
My keyless entry works for 3-4 days and than has to be reprogrammed to the car. It doesnt take long of course..but it just isn't right having people see a guy physically unlock a car as gorgeous as a C5.
Any thoughts?
And yes, I have replaced the battery in the remote.
Thanks all,
Any thoughts?
Thanks all,
I have the same problem with my 1997 fob. Supposedly this is a sign that the fob is worn out. One suggestion is to take a pencil eraser and clean the contacts for the buttons and battery on the front and back of your fob chip....it never hurts to clean electrical contacts.
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OK,,,,,,before you spend gobs of cash on new fobs and other stuff, try this:
READ YOUR DTC CODES! Post the results of what codes you find. Make sure that you include all the prefixes and suffixes for the number codes. If you have tons of codes, clear them all and read them again when the fobs fail. That will help us point you in the right direction with out having to guess.
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
[www.corvettedoctor.com
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.
If your seeing any "U" series DTC codes,,you most likely have a weak 12 VDC battery. The battery will start the car but the output voltage of the battery will DROP LOW for a millisecond or so (9 VDC) when the starter is first engaged causing the RFA & BCM to clear all of the security code information that it uses to sync the FOBs to the RFA & BCM!!! The modules in you car will shut down if the supplied voltage drops below their designed operating voltage and will not operate again until the correct voltage is present. When you car sits for a day or two, the battery can discharge enough for the output voltage to be low enough that it causes problems. If you drive it daily, it may happen a lot less often.
Allow the car to sit for a few days. Put a volt meter on the battery and have someone start the car. What do you read when the key is first turned! It shouldn't drop below 10.5-11 VDC during the starting sequence. With a new battery, you shouldn't see it dorp much lower than 11.5-11 VDC.
I bet if your seeing the FOBs reset, your also seeing the mileage trip meter, memory functions for ease entry and maybe your average fuel mileage readings reset also.
If all of the above checks out, you could possibly have a bad FOB. Yes they do go bad!! If you do find that you need to order a new FOB,,don't fall into the trap of ordering the WRONG ones. If you have a 97-2000 C5 it will only work with that series FOB. 2001 has it's FOB and 2002-2004 use their own series. Same goes for the Tire Pressure sensors! They are not interchangeable!
Please keep us informed on what you find.
Bill Curlee
Bill Curlee
Brigg (11-26-2020)
St. Jude Donor '11
key fob reset
I guess I should replace mine. When I bought the car the seller bought me a new FOB as they only had 1 old one. I decided to put that one away and just use the old one. Well it quit working a couple weeks ago. I replaced the battery and reprogrammed both FOBs. And it quit working again this weekend. Nothing else in the car has reset and the other FOB is still working.
Off to EBAY I go.......
BTW - I thought the 2000 had the special FOB?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep you are CORRECT! 2000 was SPECIAL! Sorry for the goof.
BC
BC
Received 19,561 Likes
'20-'21-'22-'23-'24
Good information. Mine is having the same problem. Going to test this out.
Same problem here. BRAND new red-top, new remote battery, checked remote contacts, checked and cleaned all grounds in electrical system, swapped fobs with backup #2 fob.....same problem. Downright annoying to say the least.
The FOB for my 98 needs to be reset after a couple of days of not driving the car also. I have a new car battery and new FOB battery, I checked the DIC for codes after the FOB quit working and NO codes show up at all, so does this mean it's a strong chance the FOB is on it's way out?
I had the Fob problem above. I r/r'd the battery and same results. Then I found my lost FOB and it worked like a champ. So, now I need to get a new FOB. And wouldn't you know it is a 2000 so I have to get the FOB that is more expensive than the others. My luck continues.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,,try a new FOB!! They do wear out and cause problems. I would try a new FOB before I rip out and replace internal modules!! I have had very good results on E-Bay!
BC
BC
Bill Curlee
Bill Curlee
Interesting findings
When sitting in the car after programming the fob, It works fine for 10 seconds and then quits. Then while starting the engine and sitting in the car and programming it while running , the fob works perfectly until I turn the engine off and then 10 seconds later I lose all FOB function. It seems like when the alternator is supplying power to the car, then, and only then, the FOB works.
Night Owl for life
Received 3,290 Likes
Well sitting in the car after programming the fob It works fine for 10 seconds and then quits. Then While starting the engine and sitting in the car and programming it while running the fob works perfectly until I turn the engine off and then 10 seconds later I lose all FOB function
BTDT.
A new fob will fix this.
Night Owl for life
Been there done that
1999 c5
1999 C5 When sitting in the car after programming the fob, It works fine for 10 seconds and then quits. Then while starting the engine and sitting in the car and programming it while running , the fob works perfectly until I turn the engine off and then 10 seconds later I lose all FOB function. It seems like when the alternator is supplying power to the car, then, and only then, the FOB works. What causes this?
Night Owl for life
^ see post 16
