Fog Lights to Match HID Headlights
Moderator
Fog Lights to Match HID Headlights Mod
I really do not like the color difference between the HID headlights and the fog lights. The fog lights look very 'yellow' compared to the headlights. So, I installed a set of Hoen High Performance Halogens. In the following photo, the fog light on the left has the Hoen bulb, the one on the right (as you are looking at the photo) has the original bulb:
Here is a side by side comparison of the two bulbs:
thanks for this post! Dont suppose you know what the bulb number is off the top of your head, my owners manual is in the vette and Id like to pick a set of these up on the way home.
Moderator
Originally Posted by Test Driver
Sweet! another awesomely, addictive thing to add to my car. *hysterical laughter*
(seriously that looks good)
It's almost tempting.
Moderator
Originally Posted by fastskyline
where did you get the bulbs?
Moderator
Originally Posted by railgun
Your car looks great with the H10. Have you also considered replacing the OEM high beam bulbs with Hoen's H9?
Moderator
Originally Posted by C6Bill
are the bulbs installed from the outside of the fender or do you have to install them from the inside of the fender?
Remove the pins from the lower fender liner then gently pull back on it. You will be able to reach in and remove the connector and then remove the bulb.
Moderator
Originally Posted by LS WON
In this pic the fog lights look the same to me
Maybe your monitor needs to be adjusted. The light on the left is much whiter in color than the light on the right. The light on the right has a yellowish tint.
but it is so slight.
Moderator
How do these Hoens compare to the Silverstars #9145ST?
