[Z06] Modified Z06 TI Exhaust - Video Inside
Sorry to re-post. I originally created this topic in the C5 general discussion rather than the Z06 forum, and seeing as this is a Z06 OEM part I would think you guys may have more interest in it!
I have never changed the TI Exhaust on my Z06 because I loved how it sounded from the factory, and then loved it even more after I put in the cam/heads last summer.
However...
A friend in the car club I am in (ShockerRacing) had a set of custom TI exhausts which essentially has a piece of titanium welded into the pipes which partially bypasses the muffler. I decided to give them a try out. It is hard to tell in the video, but the new exhaust livens the sound up a decent amount, but not to the point it is obnoxious or loses the TI sound I enjoy.
Below is a before and after video, with a couple of runs at the end to show how it sounds when driving.
http://spdkilz.com/video-audio/Video...dTIExhaust.wmv (15.1 Mb)
Opinions?
Carleton
However...
Opinions?
Carleton
Interesting... off topic but I like the ZR3 mount...I did the samething there - mounted it by modification of the bracket to bolt to the two inside tag light screws.
Originally Posted by LETHL_ZO6
BTW, would you happen to have a still pic of your Ti modification? Thanks!
Brandon -
It is a Comp Cam 232 240 .595 .610 112. I also love the sound
Slong -
What other colors are there?
Carleton
Question from the almost out of noobdom. That pass through you had welded in, is that just for sound or is it doing anything for performance as well? In either case it sounds badarse! That is one angry sounding car hehe.
I had that running through an X-FI sound card and surround sound speakers all along the walls and floor...trust me it doesn't sound stock hehe. In fact after getting a couple of opinions I am like this idea! Once I get a bit extra floating about I might look into getting this done.
Originally Posted by zeevette
Thanks for the vid. You want opinions? well, fanfreakintastic! Love the modified Ti sound.
Thanks again to all the compliments. I will try to get the exact specs/step by step instructions on how this was done (I was gone when the welding occured).
Carleton
Former Vendor
Hey Carleton
where did you have this done ?
curious about the cost
shoot me an email larry@ls1speed.com
I am very interested also, I want it! I want it! We need some details, evryone I call around here looks at me like i'm an astronaut cause I want titanium welded.
Larry -
This is what Brandon said (I am still trying to ger more info out of him):
"The titanium pipe was $30 for a 1 foot long piece of 18 gauge, 1 3/4 diameter. I got it from www.burnsstainless.com (you must call them; it is not listed in the products list) You will also need titanium cores for the welder and Chris said it was not as easy to weld with as it was using copper cores on stainless steel pipe. I'm not sure on the cost of the welder cores.
As for the labor, Chris was very generous with that. Having someone else do it might be a little pricey.
In the end, this would be much cheaper than buying a $1000 aftermarket exhaust, though."
Carleton
Carleton
Former Vendor
was it Brandon with the 3rd Gen Hawk ?
keep me informed...I am interested in having mine done. I didn't want soething too loud and your sound clip sounds great.
We can't weld TI here at the shop. I was originally trying to wled in a cutout off each area kinda where the bypass pipes are placed on yours.
thanks for the info so far
