battery drain possibly?
ok, first off I had the column lock recall done (the latest one, never had the first one) and I kept getting the pull key, wait 10 seconds every once in a while. It also would stall after starting rolling as if the first recall was done, I know it never was though. I have been really puzzled by this, tried different keys, it had a new battery last fall. Well I tried to start it today and the battery is drained. So I think I have a drain on the battery when it is not on. How do I find where the drain is coming from? If any of you have experienced this where is the likely place to start looking?
Thanks for the help.
The traditional way to check for drains was to connect a test light between the battery positive cable connector and the positive terminal. An energized light would indicate a drain on the battery. You would then systematically pull fuses until the light went out. A better method today involves using a high-amperage multimeter in the same place. See
http://autorepair.about.com/library/faqs/bl470f.htm
for a brief explaination and diagram. Since there will always be minor drains, you'd be looking for something significant enough to drain the battery quickly.
BTW, if the dealership did not actually remove your column lock and/or install a block-off plate, you may still have a working column lock. If you hear "Bzzzzt" every time you go to start your car or after you turn it off, you have a working column lock. In that case, get the bypass - pronto!
I am having this same issue as we speak on my 2004 Z06 w 9800 mi..
New Optima Battery will run down after about three days with car parked. Problem started a couple of weeks ago when I went to drive car after about a week of sitting and 2nd Delco (1st replaced two months after I bought the car ~2 yrs. ago) was dead. Up to that point nothing had changed with the car in months as far as something that could cause this condition. I have eliminated the following as causing this slow drain
* headlight relays (aftermarket)
* foglight relays (aftermarket)
* underhood light
* vanity lights
* mirror lights
* door lights
* seat motor
No evidence exists that I have got something not turning off. No lights, relay clicking, nothing. When I run a meter from positive terminal to battery post I get no evidence of current draw (meter reads 0-0.1 mA).
On battery measurement:
5/10/06 pm - 12.2V
5/11/06 am -11.8v
5/12/06 am - 11.6v
There is definitely something drawing this down. I think I will buy a battery tender this weekend and will probably take it to the shop for diagnostics as I am stumped after two weeks of trying to figure out what I've got. It seems this problem is more common than I realized...
* underhood light
* vanity lights
* mirror lights
* door lights
* seat motor
5/10/06 pm - 12.2V
5/11/06 am -11.8v
5/12/06 am - 11.6v
I don't believe it could be anything from the column lock because why would that draw power from the battery? I'm taking back to get checked out next week because it has me stumped.
i got a draw myself but i haven't had a chance to diagnose,it'll kill the battery in like 15 hours and also they did the column lock recall on my m6 and i still hear the buzzing sound from the actuator but the steering wheel no longer locks at all.
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ok!!! The newer cars with security systems, memory and automatic fob functions always have a certain ammount of current draw. Checking it with a test light just wont work.
I helped someone in the past with a problem like this and it turned out to be a bad battery.
Anyway,, here is how to see if you have an excessive current draw:
First thing that you need is a meter able to read at least 10 amps of current. Make sure that you have EVERYTHING that can draw current off, shut or removed. Stuff like, shut the trunk, shut both doors, remove the bulb or disconnect the hood light disconnect you radar detector ect.... Make sure that the meter is set up to read CURRENT and you put the leads in SERIES with the battery Then you will disconnect the negative battery cable.
Connect the meter between the battery terminal and the cable (series circuit) as shown:
When you connect the meter, you will see it go right to approx 8 amps!
This current draw is all of the modules and circuits waking up and turning on. As the BCM monitors the car and doesnt see any need to maintain the currently active circuits, it will go into SLEEP MODE and only supply power to stuff like the BCM, RFA, security circuits ect. When the car goes into in sleep mode, you will see the current drop down in steps 8, 4, 2.5. .002 and it should end up drawing right around 20 milliamps.
If you have any questions, please let me know.
Bill C
Bill C
Bill C
Bill C
Just curious, over what period of time did you find the current reduction taking place after the key was turned off?
Robert
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If I remember correctly, it was around 45 sec to a bit over 60 sec. Didnt take long at all. If yiou leave the hood light on it will take a LONG time as the BCM will have to wait for the monitored circuit timer to shut the hood light off!
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats correct!! If you set up the car so that nothing that uses RAP (Retained Ascessory Power) is on, it will not come into play (i.e. the hood light, open door, open trunk ect. With in approx 2 min, you should be down to minimum amps, .002
