california duster..
Originally Posted by RAGOVET
I find it OK to use for loose dust and provided you DO NOT place any pressure on it against the surface of the car. Just lightly dust it.
But I mean if it is bad definately wash it. If your not sure you can never go wrong with a wash.
Only if you use it once a day, or 2 days max.
The build up of dust will be like a micro sandpaper sheet.
It is better to leave it dirt until you can wash it.
LEX
LEX
You can ONLY use if you use the backhanded asymetrical left hand grip if you're right handed. If presents unique problems if you're left handed. Left handed you MUST use the modified hyperbolic right handed technique WITH the left hand rule of thumb pattern. VERY, VERY important! And remember, left or right handed, all cooling vents MUST be in the full open position stationed at 30.6 degrees.
Rick
Rick
St. Jude Donor '05
Rick
Rick
