I could make the profanity filter implode with this post
Cruise-In IV Veteran
so instead of swearing, I'm going to use the word vacuum
I can not vacuuming believe this vacuum. I was outside blending base coat on my hood that got scratched to vacuum while being stored for the past year. While blending the base, I was only running the edges since thats where the damage was done and on the rear corner of the hood (was chipped off and did a small fix).
I was colorsanding the base today near the edges and put down my first coat of clear. everything looked fine and dandy till I put my heavy coat on. Thats when I realized the paint which I bought pre mixed right from the vacuuming paint shop doesnt vacuuming match. I'm so gawd vacuum vacuumed off right now. I just can not believe it doesnt match.. it's like not even vacuuming close to the right tint.
Why the VACUUM couldnt I have painted the vaccuming car black !!!
matching up paint isn't as easy as simply going in and saying "I need Red (or whatever color)". Even black is hard to match. There must me over 100 shades of black!
When we painted my car last year it took almost a dozen sample pints mixed up before we got the color correct.
ALWAYS spray ot paint a sample test piece and let it dry and compare it to the rest of the car before using it to check the color to see how well it matches.
We kept about 1/2 quart we had left over after my paint job for futire repairs so we KNEW it would match and on top of that I got the custom paint formula of the mix from the PPG supplier in case I ever need to order more.
sorry about your frustration, I know it sucks to have to go through this, but it's not uncommon.
Just another Corvette guy
holy vacuum Bro'......that sucks.
this was how it looked BEFORE the scratch.. i didnt take pictures of the scratch since it wasnt worth documenting..
that was no wetsanding, right out of the gun..
here is the "repair" after clear.. I think my gun needs some adjustment too
gee, I wonder where the blend is
that sucks or blows depending on which side you put the hose on the "vaccuum"
shizzam
shizzam
Unless you are extremely lucky, you will have to blend the upper surround also. Even if you get the color dead-nuts on, the metallic lay-down will be different. Edge painting sucks because you have to paint a perfectly good adjacent panel. G/L
Originally Posted by yellow 72
Even different gun settings can sometime effect color shades in some pigments....I'm surprised the self proclaimed "forum paint guru" didn't know that
Originally Posted by 1Z87L8
man that vacuum streak will hang over CT for the next 20 years
sory corz... that vacuuming sucks.
Originally Posted by JoeRags
lets hope not... I dont need any more vacuuming problems...
