The Grond Chronicles : Anatomy of a Coilover [Dialup: you know the script]
Supporting Tuner
I bought Doug Rippie Motorsports (DRM) coilovers last year along with GM Racing T1 swaybars and subsequently dumped my entire stock suspension. I absolutely love my suspension - I could never go back to a transverse leaf now.
The DRM coilovers I have are custom shortened and revalved, but the rear springs were a little too soft for me. So I asked Randy (Rippie) of DRM to send me 650 inch/lb springs to replace the 550 inch/lb ones I currently have. By the way, Customer service at DRM is top notch - I can't say enough good things about them !!
Also, since my supercharger install, I have to raise the front by about 3/4 inch. So today was suspension day (among other things )
Well, I finally got around to raising the front and swapping the rear springs, so I thought I would post some pics of the dissembled coilovers.
Special shortened coilovers
They need cleaning after 7 months of driving
Dissembled coilovers
Stiffer springs - which will allow me to go lower
Back together again - now to reinstall.
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
So what are you doing in your spare time ??? Sounds like you need to come up here and stay close to my car for awhile I could check in with you from work once in awhile and see how things were going
Lookin' good my friend
Life Time NCM #2196
I love the look of those coil overs and believe that is the route I will go when I dump my F-45 system. How much for the normal coil overs as I do not quite need to drag the weeds like the Grond, however lower than what I have now will be fine and the superior handling they must provide is really what I am after and with a blower I will need my front about where it is for proper cooling
Looking good! Have you tracked the car any?
Supporting Tuner
And in my spare time? I am also doing this....
Supporting Tuner
Originally Posted by 74-Roadster
Looking good! Have you tracked the car any?.
Supporting Tuner
Originally Posted by connecticut
first A4 in the country to use DRM coilovers
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Originally Posted by EnglandGreen
... since my supercharger install, I have to raise the front by about 3/4 inch.
Cruise-In II Veteran
No I have not tracked it yet. Still getting it set up the way I want it.
Supporting Tuner
Originally Posted by Sully C5
You really need to get her on the track because running a road course is a very different animal than driving on the street. Before you spend more $$$ you should should get on the track & find your weakest link...you may be surprised.
Supporting Tuner
Originally Posted by Cajundude
What are the advantages of coil overs?
Seriously, it allows you to have absolute control over your suspension - ride height, corner balance, and true independent suspension. If you road race, you can setup your car for each course (if you wanted to).
I got them for 4 reasons.
1> I hated the stock suspension and Z06/Hotchkiss/QA/VB&P et al did NOT do it for me
2> I like total control
3> Ride height adjustability
4> Stiff suspension - like a race car.
Supporting Tuner
My lower radiator mount touches the road when I drive on a bumpy road. That is the only reason I am raising the front a little bit.
Prior to the new ECS radiator mount, I drove it like this all over the country for about 9,000 miles.
Location: Mustangs are like Tampons.. Every P*$$* has one!
It would be my honour to do anything at all on your awesome ride, GB. You know that.
