[Z06] Air Charger Installed ...interesting Results
Just had the Air Charger installed yesterday by LAPD in Chatsworth, CA. (they previously installed Kooks 1 7/8 inch long tube headers and did dyno tuning). LAPD is the first official distributor of the Air Charger in the LA area. Prior to te installation, my Z dynoed at 494.62 RWHP and 458.14 RWTorque. (with headers and tuning). With the Air Charger, the numbers are 498.31RWHP and 467.05 RWTorque. I was present for the dyno tuning after the Air Charger was installed, and the tuner did 42 runs to finally get the optimum REAL numbers. I learned alot about tuning by being present. It's facinating! I was surprised that the HP increase was low, but the torque increase was a bit higher than expected. It was explained to me that an aftermarket airbox will get a bit less of an increase in numbers on a car that has headers as opposed to a car without. And different cars will have slightly different numbers since these motors are hand built. Also, advertised increases with some companies must be taken with a grain of salt. But I am quite happy with all of this because I can feel a difference in power in real world driving at higher speeds. And I know that Doug (the tuner at LAPD) is as good as anyone out there, and no one could have gotten higher numbers on my car. So yes, I do recommend the Air Charger, but don't expect miracles. It's just a bolt on airbox...not a cam or blower!
Leeds.io
St. Jude Donor '14-'15-'16
i agree totally.
i went from 460 to 489 with the aircharger and tune. While gaining another 30rwhp with the headers would be nice I wouldn't expect anymore than a 15-20hp gain.
Premium Supporting Vendor
Location: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Brian, what... you mean you don't do 42 runs on your car to dial it in? That would just about empty the gas tank
Former Vendor
And yes I will agree with you, there is a lot of BS floating around this forum about dyno numbers and track performances. I like having my car dyno back to back to back ensuring good solid results. The same goes for the track; I like to see myself repeat a great run at least twice times before calling it quits.... if track allows me!
Congrats and keep us updated.
Originally Posted by Cobra4B
42 pulls.... my ***.
Remember the air charger works by obtaining colder air outside the engine compartment... it'll work better when you're actually moving.
Of course you are correct...that is why a good tuner has a giant fan in front of the car that can simulate air speeds at different fan speeds.
But I do not understand the comment about your ***.
Originally Posted by Myhardtop
It sounds like you are happy with the results Mr. Ronnie CZ06. Dorn it, just 1.7rwhp away from 500 on the dyno! Well, drive it more and then check back. Often like on the old LS1's motors, a little more power can be had after some learning miles. And as you mentioned, on the road you will be making every bit of 500rwhp or more since air will be ramming in. Another thing to consider is L.A where you currently reside; the highest premium gasoline is 91 octane! A couple of points may help you achieve that 500 mark...just my guess.
You made some very good points, all of which I agree with. It would have been nice to hit 500RHP, but what the hell...the real fun is in the driving...not the numbers!
Hi RonnieC6Z,
Are you running 93 octane or 91? That can mean a difference to you of about 2/91 * 498.3 = approx 11 hp!
oops I missed the post by myhardtop right above me. There has to be 100 octane unleaded in the ground somewhere around you then you can blend your 91 and 100 to obtain 93+
Former Vendor
Originally Posted by Adrenaline Junky
Hi RonnieC6Z,
Wait Mr. Junky, you live in LA and you pulled something like 508rwhp with similar mods and the air-charger with a EW pump...right?
If so, then Ronnie get some 93 octane buddy, this is a 11.1 motor !
Hi RonnieC6Z,
Good thinking on your part...there is a station 5 minutes away that has 100 octane.
Unfortunately, your timing has to be adjusted again to accommodate the 93, but it looks like you should get at least 11 more rwhp! I've kept my blend above 93.2 for about 1500 miles now and it makes a noticeable difference, not a big difference but if you tweak your engine with 6 such improvements----------
Wow, is that right!
I actually live "near LA" --- in Northern California about a 5.75 hr ride on Hwy 5
Congrats Ronnie!That is impressive.The more I read the more intersted I get.A guy at the track I met had headers and the exhaust switch.Man that thing sounded sweet.
I agree...I have the exhaust switch (which is almost always open) and LAPD did my Kooks headers. The car really sounds like a big block 427. Al, the GM at LAPD, built his own exhaust system for his 01 Z, (very modified motor) and I think my Z sound just as good, and Al's sounds great!
If so what did it do for performance or did it hurt it?
Originally Posted by DoSvdanye
Did you run with the exhaust switch closed on any of them?
