[Z06] New Shipment Of LS7 Clutches Arrived!
Hi All,
We just received a new shipment of LS7 clutches and flywheels. You can order them conveniently online @ any time from www.fredbeansparts.com. Click where it says click here to search by part number. Use the following part numbers under Chevrolet make.
12571611 flywheel - 178.00
24236500 clutch disc and pressure plate - 287.09
You can add any of the following components to the clutch order.
89059282 Z06 slave cylinder - 101.83
12564455 Z06 master cylinder - 103.86
14061685 pilot bearing - 9.53
We look forward to hearing from you!
Thanks,
Gene
Thanks,
Gene
