Some Steering Box Pic's
gone
Gary, what approximately is the turnaround time if i sent u my steering box?
As always, great pics and good tips. Almost makes me want to go out and tear into my steering box setting on the shelf just try and do the job my self. Thanks for the post Gary.
Great post Gary. Like Eddie....makes me want to tear into mine. You forget....I'm retired now and supposed to be taking it easy....and here ya go putting ideas into my head again..... .
My steering is very sloppy.... the guy we bought our frame from told us the steering bos was "rebuilt." After driving the car 6 years later, after the whole resto... its crap.
Whats average cost to rebuild if the gears are good? and if it needs new gears?
Im right up the street from you... I may be interested.
Joe
Joe
Joe
Joe
Hello Gary, whats the cost to do a rebuild? I don't have mine apart yet but might be ready in a couple weeks. You can contact me directly at; frank@itpphoto.com
Thanks,
Frank
Thanks,
Frank
Originally Posted by steves_77vette
Before assuming it's the steering box, check the power steering control valve as well. You can get some slop from that piece as well.
Thanks.
Thanks, I'll do that. What do I look for while inspecting it? I would imagine is has to be disassembled, no?
Thanks.
Thanks.
Steering Column length
Gary
Nice pics & info. My '61 has a replacement box & column, It stick out 2-3" behond the dash. I think it's from an early C1 . What would you suggest? The vette steer is good, just steering wheel extension behond the dash,
Thanks Rich
Thanks Rich
Originally Posted by gtr1999
Thanks guys, I appreciate the response and hope it helps you out.
Thx Gary, so much information and pic's too. I was just this week discussing steering rebuilds but we were more into the power systems than the box. Now after reading your visual inspection post, I do have an issue with the box's response vs the movement of the steering wheel. So, the box is on my list also.
I have a question if you wouldn't mind responding when you have the time. Will you discuss a bit the broad spread of steering ratios? ie: 12:1 to 22:1 and in between. Any positive or negative reasons? Probably racing and autocrossing applications fit in here somewhere. Is there any reason for changing the stock ratio, whatever that may be on my '78 L48/TH350? I do like what I have, but have nothing else to compare.
Thank-you again,
DOUG...
Wow, thanks for this thread. I started a thread a couple weeks ago aout this and got so busy I couldn't check replies until today and found this first. Thanks Thanks Thanks!
CF Veteran
St. Jude Donor '10-'12
Gary - Seems like you've been busy. Great thread! I will probably end up sending you my box also. Ever rebuilt a power steering valve? Mine is leaking...
