My New 408 and T88 Pic's inside
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I will have more Pictures soon, We have been working late nights trying to get this finished
There is alot more done than these Picture's show I will try to post more this weekend
I'm still no sure if we are going to mount these Blowoff's here or not
Do to the size of the T88 Turbo We had to relocate the EBCM to the front next to the intercooler
Damn!!!!!!! That chit is hot!!!
What kind of hp goals? 800? 1,000?
Cruise-In V Veteran
Just a thought, but are you going to wrap your headders to reduce radiating heat from warming up your air comming out of the intercooler before going into ur intake of the engine?
Is it me or does that T88 seem rather small in comparison to your eingine
Supporting Vendor
all of the hot pipes are going to be coated in a 2000 degree coating and there will be heat sheilds in the spots that are needed like the spot you mentioned along with the brake booster/master cylinder and the valve covers will have heat sheilds. we should have the charge piping and intercooler and the aluminum radiator shroud finished by the end of the weekend. then all we have to do is the oil lines and a few other things and we will be ready to get some numbers off of this beast. we have a fan on order since the big single will not allow you to use the stock fans and the fan flows 3980 cfm and is only 3.5 inches thick. the 76 kit is following along right behind this one. we have had many delays in this kit due to our header supplier and we still dont even have our originals back yet so we decided to go ahead and make 2 new sets so we can have our numbers. our supplier just left me a message saying my origianls and a preproduction sample will ship to day but who knows at this point.
sorry for not using the proper punctuatuion and making it one big run
Cruise-In V Veteran
I will have to use a rather large turbo blanket also
I realy don't think that heat is going to be an issue
Its cool i am no gramar ****.
Good to see you guys are not just doing wraps but coating (done by jethot?)
I am excited to see your finnal product. Iirc you guys are going to be offering this kit for pennies compared to other kits out there. (right?)
That looks ABSOLUTELY WICKED! In your signature, it says that you have 4.10's. With all of the power that you're going to be making, are you going to something a little higher (lower numerically)?
Cruise-In V Veteran
I may have to use 3.15
