Post your Race Parts 4 Sale HERE
#101
Former Vendor
lite weight hood
I am selling a liteweight racing hood for C4 Corvette. The hood has louvers in the center as well as over the wheels. It is fiberglass. It is manufactured for me by 5 Star Racing Products using a new process that gets the weight down to near carbon fiber weight at half the cost. The hood weighs aproximately 22 pounds! I am selling them for $1400 plus shipping. I can't seam to figure out how to post pictures here. If interested, pm me and I will send you a picture.
#102
Need brake pad upgrade
Wanted: Looking for a set of Carbotech panthers (AX6 or something now), X8's, or even good Z06 pads for my '99. Only run a couple of DE's a year and don't stand on them a lot so I just need an upgrade.
Thanks in advance.
Thanks in advance.
#104
gs96c599@aol.com label it
HOOD PICTURE********************
so I don't miss it.
#105
FS Mostly 63-77 parts & race items.
Prices DO NOT INCLUDE SHIPPING.
Pictures available for all items.
PM me or rp.bp89@***.net
Rick
San Diego, CA.
Built LT-1 350 engine (dyno 425hp), 10.5 compression, all 010 blockwork performed, reworked and flowed Bowtie aluminum heads w/2.02 & 1.60 valves, Victor Jr., roller cam, complete except for carb and roller rockers. Professionally built. $2,500.
Rebuilt with new parts, M22, all-alloy 4-spd transmission, w/Hurst Quick shifter and reverse lockout, $1200.
Rebuilt with new parts, 4.11 posi differential w/yokes and powder coated cover, $1000.
Stock front upper ($50) and lower ($50) suspension A-arms.
New front poly bushings, new rear strut bushings, $20 per set
Front coil spring sets, 500lb, 600lb, $30 per set
Stock 5-leaf rear spring, $50
'66 & '67 parts 2 used red tail lights, 2 half shafts, $15 ea.
Notched rear trailing arms for bigger tires, $80
Notched rear cross bar for lowering the rear, $75
The notched trailing arms and the notched cross bar are stock ones that had been notched.
(Bass Racing) Professional aluminum scale platforms, $250
CSI Billet S/B Electric Water Pump, $160
LONGACRE, ACCU-TECH, Digital Racing Tire Pyrometer, $55
Rod Minor Camber/Caster Gauge, $35
Rod Minor Wheel Load Checker, $45
S/B Alternator, Water pump, Starter, Power steering pump w/pulley.
S/B Offenhauser Dual-port Intake manifold, $90
Edelbrock S/B chrome valve covers w/K&N breathers, $60
Rick
San Diego, CA.
#106
Accusump hose for C5
I had this hose made up for my Accusump. It is 32" inch long which is perfect for use with Parker part number 8M16C80MX and ASump mounted in left fender. Has 1/2" male JIC<>1/2" male pipe to fit into Accusump valve.
$20 SOLD> thanks, Perry
#109
Hello.
I would like to buy this from you. Sent you a PM
Thanks, Perry
#110
F/S -Pair of Simpson #29063 Harness
F/S - Two individual sets of red Simpson 55" bolt-in, pull-down,5-point harness. Simpson part #29063. SAFI Spec 16.1 manufactured February 2003.
Some light wear and tear from ocassionally autocross and track day use with C4 coupe and ASM Harness bar.
$50 plus shipping for 13 lbs. SOLD in C4 Forum
See photo at http://www.photohost.org/gallery/sho...1/cat/2/page/1
#111
Kumho 710s (17") for sale.
These are 275s (front) and 315s (rear) which were used for one (two day) event at Watkins Glen last year. Stored indoors off the car since then. I am doing WG again next month, and do not want to use year old tires on a high speed track, but these are practically full tread, and would be great for autocross or street.
I am asking $400 for the four delivered by UPS or Fedex to the lower 48.
#112
Any pics?
#114
Kumho V710's 315/35ZR18
If anyone is interested I have a few sets of Kumho V710's in size 315/35ZR18.
They have 3 to 4 heat cycles on them. Lots of rubber left.
$150.00 per pair plus shipping.
Thanks, Perry
Thanks, Perry
#115
WTB road race slicks
khumos v710 or hoosier r6 or michelin sport cups or toyo ra1...etc
285/30/18's 4 matching if you have them!
and/or a very rare size 265/40/17 if available 4 matching
#118
#119
#120
4 sets of c5 size rear brake pads
cleaning out the shop, I have 4 sets of c5 size rear brake pads. I went to full big brakes so I don't need these.
stock z06, 95+% (practically new), (sold)
pfc01, 75% (3 30 minute sessions), (sold)
carbotech p+, 75% (street miles), $75
carbotech xp10, brand new, (sold)
