Trans and rear diff numbers
I copied the numbers off of the trans and diff on my 65. Is the Vin# usually stamped onto the trans? Not sure how all these decode but here goes.
Cars Vin is 194675S101340.
Trans:
Stamped numers 19S720103 P9C11B
Casting number 3925660
There is also a little metal tag on the cover. Not sure if the first number is a 3 or not
Tag: (3?)946798
________________________________________ __________________
Rear diff:
AP 9 1764
I assume the 1764 calculates into the ratio? 3:73? Not sure what the AP 9 means though.
Trans:
Tag: (3?)946798
Rear diff:
AP 9 1764
Rear diff:
AP 9 1764
Rear diff:
AP 9 1764
Trans:
Tag: (3?)946798
Trans:
Tag: (3?)946798
A quick google search found this website:
http://www.5speeds.com/muncie2.htm
Looks like you have a 68-70 main case..I say main case, because depending on the wear and tear on the car previously, you could have a transmission made up of multiple donor units.
Originally Posted by RGGregory
Actually, AP is the code for the r-end ratio - in your case 4.11! How many rpms are you pulling at 40 or 50 mph? 9 17 64, should be the assembly date of the r-end - Sept 17th, 1964.
It is screaming on the freeway 3500RPM@about 68/70 MPH
Thanks for the info Time for a Keisler 5 Speed
This measurement method will overcome any errors in your speedometer and/or tachometer
PS - it will be easier to stop counting on a full rotation of the driveshaft, since with the tire right in front of you and with a bigger diameter, it will be easier to determine what fraction of 360 degrees the last tire turn was (that's why turning the wheel more than one time will help - the more turns, the easier it will be to discriminate between 3.55, 3.70, 4.11, etc.
http://forums.corvetteforum.com/show...285&forum_id=4 this recent post is on the ratio counting thing..same topic comes up at least once a month, it seems.
Received 1,857 Likes
Trans:
Tag: (3?)946798
Rear diff:
AP 9 1764
Tag: (3?)946798
Rear diff:
AP 9 1764
Originally Posted by stratplus
I am not sure what this tells me. I spun the tire 3 times and the driveshaft turned 5 times. This is a non posi. So what is the ratio?
