A List of the Voice Recognition Commands
It's not pretty but here is a list of voice commands available pasted from the Navigation Manual. There are ALOT of them!
The following list shows all of the voice commands available for the navigation system with a brief description of each. Any words shown in square brackets are optional. If there are words shown in parentheses, choose one of the options. To use the voice commands, refer to the instructions listed previously.
Help Commands
These commands are universal and will enable you to use the help prompts available from the system.
Command Help/List
This command will enable the system to provide the available commands for the navigation radio.
Cancel
This command cancels the voice recognition function.
Radio Commands
Radio
This command will change the audio system to the next radio audio source.
AM
This command will change the audio system to the AM audio source.
FM1
This command will change the audio system to the FM1 audio source.
FM2
This command will change the audio system to the FM2 audio source.
XM1
This command will change the audio system to the XM1 audio source.
XM2
This command will change the audio system to the XM2 audio source.
Power On, Audio On
These commands will turn the system's power on.
Power Off, Audio Off
These commands will turn the system's power off.
Seek Up
This command will cause the selected audio source to seek up to the next strongest signal.
Seek Down
This command will cause the selected audio source to seek down to the next strongest signal.
Stop Scan
This command will cause the audio source to stop scanning for the next strongest signal.
CD Player Commands
Track Up
This command will cause the CD player to skip up to the next track.
Previous Track
This command will cause the CD player to go to the previous track.
Track Down
This command will cause the CD player to go to the beginning of the track or go to the previous track if the counter is less than 9 seconds.
Screen Commands
Screen Day Mode, Day Mode On
These commands will adjust the system's screen setting to the day mode.
Screen Night Mode, Night Mode On
These commands will adjust the system's screen setting to the night mode.
Screen Auto Mode, Auto Mode On
These commands will adjust the system's screen setting to auto mode.
Screen Off
This command will turn the system's screen display off.
Position Commands
Current Position, Current Location, Show Current Position, Show Current Location
These commands will cause the system to display the vehicle's current location on the map screen.
Map
This command will cause the system to display the map screen.
Map Commands
Zoom In
This command will cause the system to zoom in when on the map screen.
Zoom In Maximum
This command will cause the system to zoom in to the minimum available map scale when on the map screen.
Zoom Out
This command will cause the system to zoom out when on the map screen.
Zoom Out Maximum
This command will cause the system to zoom out to the maximum available map scale when on the map screen.
Heading Up, Change to Heading Up
These commands will cause the system to display the Vehicle Up heading when on the map screen.
North Up, Change to North Up
These commands will cause the system to display the North Up heading when on the map screen.
Map Direction, Change Map Direction
These commands will cause the system to change the vehicle's direction from North up to heading up or heading up to North up on the map screen.
Mark, Mark This Point
These commands will cause the system to mark the location as a memory point while on the map screen.
Right Map Zoom In
This command will cause the system to zoom in on the right map when in dual map mode.
Right Map Zoom In (Maximum/Minimum Scale)
This command will cause the system to zoom in to the minimum available map scale on the right map when in dual map mode.
Right Map Zoom Out
This command will cause the system to zoom out on the right map when in dual map mode.
Right Map Zoom Out (Maximum/Maximum Scale)
This command will cause the system to zoom out to the maximum available map scale on the right map when in dual map mode.
Right Map [Change to] / [Show] North Up [Mode]
These commands will cause the system to display the North Up heading on the right map when on the map screen in dual map mode.
Right Map [Change to] / [Show] Heading Up [Mode]
These commands will cause the system to display the Vehicle Up heading on the right map when on the map screen and in dual map mode.
Right Map [Change Map] Direction
This command will cause the system to change from North Up to Heading Up or from Heading Up to North Up.
[Show/Change to] Dual Map Mode
This command will cause the system to change the map display to dual map mode.
[Show/Change to] Single Map Mode
This command will cause the system to change the map display to single map mode.
[Change to] 3D Map [Mode]
This command will cause the system to change the map display to the 3-dimensional map.
[Change to] 2D Map [Mode]
This command will cause the system to change the map display to the 2-dimensional map.
Destination Commands
Home, Go Home
These commands will cause the system to enter the Home destination as a waypoint or final destination, if one is set.
Go to Starting Point, Previous Starting Point
These commands will cause the system to enter the last available starting point as a waypoint or final destination.
[Go to] Previous Destination
This command will cause the system to enter the last available destination as a waypoint or final destination, if one is available.
[Go to] Preset Destination [Number] (number)
This command will cause the system to go to the preset destination number. This preset destination can be chosen as a waypoint or a destination. There must be a location stored in the preset destination number that is chosen. For example, first store a location in Preset Destination 3. Say "Go to Preset Destination 3." The system will go to Preset Destination 3 and prompt you to choose it as a waypoint or destination.
Add [to] Waypoint
This command will cause the system to add the current marked point as a waypoint. This command is used after the following commands have been used: Home, Go to Starting Point, Go to Previous Destination.
Enter Destination
This command will cause the system to add the current marked point as the final destination. This command is used after the following commands have been used: Home, Go to Starting Point, Go to Previous Destination.
Guidance Commands
Repeat Guidance, Repeat Voice
These commands will cause the system to repeat the last available voice prompt guidance command if a destination has been set.
Louder
This command will cause the system to increase the volume of the navigation voice prompts.
Softer
This command will cause the system to decrease the volume of the navigation voice prompts.
Voice Guidance Off
This command will cause the system to turn off the navigation voice prompts if a destination has been set.
Voice Guidance On
This command will cause the system to turn on the navigation voice prompts.
[Change to] Arrow (Guide/Guidance)
These commands will cause the system to change to Arrow Guidance screen view in the Guidance Menu if a destination has been set.
[Change to] Turn List (Guide/Guidance)
These commands will cause the system to change to Turn List Guidance screen view in the Guidance Menu if a destination has been set.
[Change to] Freeway (Guide/Guidance)
These commands will cause the system to change to Freeway Guidance screen view in the Guidance Menu if a destination has been set. This command is only available if you are on a freeway.
[Change to] Intersection (Guide/Guidance)
These commands will cause the system to change to Intersection Guidance screen view in the Guidance Menu if a destination has been set. This command is only available when the next turn is less than 0.5 mile (800 m) away for city streets and 2 miles (2 km) away for freeways.
Entire Route, Entire Rout Map, Route Overview
These commands will cause the system to display the entire route if a destination has been set.
Reroute
This command will cause the system to generate an alternate route to a set destination while on a planned route.
Detour, Detour Entire Route
These commands will cause the system to activate the detour feature when driving a planned route.
Next Waypoint Map
This command will cause the system to display the map view of the next waypoint location if one has been set.
(First/Second/Third/Fourth/Fifth) Waypoint Map
This command will cause the system to display the map view of the named waypoint location if it has been set.
Destination Map
This command will cause the system to display the map view of the final destination location if one has been set.
Yes
This command will confirm system talkback.
No
This command will cancel a command.
(Delete/Cancel) Destination
This command will cause the system to cancel the current destination.
(Delete/Cancel) All Waypoints and Destination
This command will cause the system to cancel all currently set waypoints and the final destination.
Quick
This command will cause the system to select the Quick route when a destination has been set.
Normal
This command will cause the system to select the Normal route when a destination has been set.
Short
This command will cause the system to select the Short route when a destination has been set.
Point of Interest (POI) Commands
The following commands will cause the system to display icons if they are available on the map screen when the map scale is set to ½ mile (1 km) or less.
Automobile Commands
• Auto Service And Maintenance, Auto Service, Maintenance
• Automobile Club, Triple A
• Car Park
• Car Wash
• Gas Station, Gas
• Other Automotive
• Parking
• Parking Garage
• Parking Lot
• Rental Car Agency
Entertainment Locations
• Amusement Park
• Botanical garden
• Campground
• Casino
• Cinema
• Golf Course
• Horse Racing
• Marina
• Museum
• National and State Parks
• Park & Recreation, Parks & Recreation
• Performing Arts
• Ski Resort, Skiing
• Speedway
• Sport Complex, Stadium
• Tourist Attraction
• Video Rental
• Winery
• Zoological garden
Financial and Government Offices
• ATM
• Bank
• Business Facility
• City Hall
• Civic Center, Community Center
• Convention Center, Exhibition Center
• Court House
• Government Offices
• Higher Education, University, College
• Hospital
• Library
• Other Financial Services
• Police Station
• Post Office
• School
• City Center
Personal Services
• Beauty and Barber Shops
• Dry Cleaning
• Health and Fitness Club
Restaurant Locations
• American Restaurant, American Food
• Chinese Restaurant, Chinese Food
• Coffee House
• Continental Restaurant, Continental Food
• French Restaurant, French Food
• Ice Cream Parlor
• Italian Restaurant, Italian Food
• Japanese Restaurant, Japanese Food
• Mexican Restaurant, Mexican Food
• Other Restaurant, Other Food
• Restaurant, I'm Hungry
• Seafood Restaurant, Seafood
• Show Restaurant
• Thai Restaurant, Thai Food
Shopping Locations
• Convenience Store
• Department Store
• Grocery Store
• Home and Garden
• Other Retail Store
• Pharmacy
• Shopping, Shopping Mall
• Specialty Food Store
Transportation
• Airport
• Bus Station
• Ferry Terminal
• Historical Monument
• Hotel
• Park & Ride
• Rest Area, Rest Stop
• Tourist Information
• Train Station
POI Off
This command will cause the system to turn off POIs so they do not appear on the map screen.
Help Commands
Command Help/List
Cancel
Radio Commands
Radio
AM
FM1
FM2
XM1
XM2
Power On, Audio On
Seek Up
Seek Down
Stop Scan
CD Player Commands
Track Up
Previous Track
Track Down
Screen Commands
Screen Off
Position Commands
Map
Map Commands
Zoom In
Zoom In Maximum
Zoom Out
Zoom Out Maximum
Right Map Zoom In
Right Map Zoom Out
Home, Go Home
Add [to] Waypoint
Enter Destination
Guidance Commands
Louder
Softer
Voice Guidance Off
Voice Guidance On
Reroute
Next Waypoint Map
Destination Map
Yes
No
Quick
Normal
Short
Automobile Commands
• Car Park
• Car Wash
• Gas Station, Gas
• Other Automotive
• Parking
• Parking Garage
• Parking Lot
• Rental Car Agency
• Amusement Park
• Botanical garden
• Campground
• Casino
• Cinema
• Golf Course
• Horse Racing
• Marina
• Museum
• Performing Arts
• Speedway
• Video Rental
• Winery
• Zoological garden
• ATM
• Bank
• Business Facility
• City Hall
• Court House
• Hospital
• Library
• Police Station
• Post Office
• School
• City Center
Personal Services
• Dry Cleaning
• Coffee House
• Ice Cream Parlor
• Show Restaurant
Shopping Locations
• Convenience Store
• Department Store
• Grocery Store
• Home and Garden
• Pharmacy
Transportation
• Airport
• Bus Station
• Ferry Terminal
• Hotel
• Park & Ride
• Train Station
POI Off
I've tried mine a few times and probably gave the wrong commands because it comes back with something I didn't want. I find it easier to just use the buttons...especially since I don't really use too many of the functions.
Thanks for the list though.
Originally Posted by Jagcvette
Wow, that was a lot of trouble. Thanks for posting. By the time you find the right command, you could have already done it manually.
Originally Posted by Yacht Captain
Chris,
Many thanks for your tedious effort.
Bob
Bob
Location: ...tearing up the highways, one state at a time™®©
Received 2,102 Likes
...I know a few that DON'T work - but we tried
BTW, Italian Resturaunt was by far, the best one I have used
Find the voice recognition system so difficult to use. It "never" understands what I say, sometimes I can't even guess what it interprets. It is too bad because voice recognition might be great but first of all the button for voice should be on steering wheel(as many others so you don't have to take hand off wheel and glance for button) and then it should work.
I don't use it anymore.
The other day I was showing off the Nav voice commands to a colleague who is thinking about buying a 'Vette. First I said "zoom out" and it responded "zooming out". He was impressed. Then just for grins I said "F*** You!" and it responded something like "displaying amusement and recreation locations"!
We laughed our butts off.
I wonder how many other non-documented commands exist.
Originally Posted by antoniopaolo
Thanks Chris for taking the time to post all of this information.
Quite an effort. Much appreciated.
antoniopaolo
antoniopaolo
No problem. It was really not effort at all. I copied and pasted it from the Navigation Manual. Since then I pasted it into Excel and cleaned it up so it printed out nicely. email me if you'd like a copy...
Many thanks for this. Very appreciated.
Wow! It must be raining in your neck of the woods. Thanks for your time and effort. I am going to try a cut and past to several index cards then laminate. "pdmviper off"
