Gas Gauge Inaccuracy
Still working my way through the bugs in my new '65. Latest problem is gas gauge reads 1/4 when tank full and empty when tank is empty. Any way to test the gauge and how do you start on testing the sender?
I have a similar problem, when the car is off the guage shows about 1/8 of a tank regardless of how much fuel is in the tank. When I put the key in and turn it on or start it up the guage goes from 1/8 to empty and stays there while driving, regardless of how much fuel is in the tank. Any ideas and what is the procedure to fix it. I used the search function to look for past threads but only found 2. Thanks
In the Feb 2006 "Corvette Enthusiast" edition, John Hinkley wrote a comprehensive article on troubleshooting C-2 fuel gauge and sender system.
You can get backissues at (800) 448 3611.
Wounded Warrior Escort '11
St. Jude Donor '05
Gas Gauge
When I got a brand new '66 the gas gauge was off----every c-2 I have had the gas gauge has been off high or low---carry a stick-- Firedog
Only too true!
Geek
When I re-installed my new gas gauge. I had the wires reversed on the gauge. It would read nearly empty instead of full. Just thought I would mention it to make sure your wires are on the correct terminals.
I'm not the only one!!
Mine works perfectly - 18 years now.
Drain the tank. Pull the sender. Clean the resistor wire with a scotch pad, and check the gauge settings while it's out of the tank. If cleaning doesn't do it you have to replace the sender.
If you decide to replace it, be careful to check the repop before you install it. There were a lot of defective repop senders made a few years back.
Not meaning to highjack but my gas gauge has starting acting erratic jumping between 3/4 and 1/4, the needle is never still, checked cluster ground and it's good, suggestions?
The gauge was reading around a half tank but when I looked in the tank it was bone dry.
It's a good thing they made the tank easy to look into because every C2 I've had has had the same problem.
I found out early-on that my gas guage didn't work. On the day that purchased the car, I was two doors away from home when it sputtered and died (uphill to my driveway on an icy road, so I couldn't push it). Talk about your panic attack! Having just written a BIG check, was I ever PO'd! Once I calmed down and thought it through, I realized that I'd run out of gas. I filled it up, and prayed that the marginal battery would have enough life (after repeated cranking on empty) to bring the engine back to life. It did. But no matter how far I drove, I always had at least 1/4 of a tank by the guage. The stick method worked well until I ultimately replaced the sender. The guage has been accurate ever since.
I reset my odometer each time I fill up. I refuel @ 180 miles with a couple of gallons still in the tank. Even with my new guage, it registers 1/4 off it seems.
St. Jude Donor '05
Stick
If I came up with a custom made Corvette gas tank calibrated stick, do you think I could sell them on E-Bay??? I could use some cash for parts. Firedog
