New crate engine is now a steam engine....bad problem...
Old 03-05-2006, 01:21 PM
MsVetteMan
MsVetteMan's Avatar
Default New crate engine is now a steam engine....bad problem...
Trouble in Paradise. Think I either blew a head gasket, or have a cracked head. Cranked her this morning and backed out into the driveway to let her warm up and check all the fluids. Noticed water coming from under the car, looked and water was spraying out of the right side header!! Immediately cut her off and checked the oil.....milky, really milky. Dayum......I (we) followed the instructions to a tee, and the motor never got over 200*. Never lost oil pressure, and still show very good oil pressure. Motor will crank easy, but has a little rougher idle. Only drove her a 1/2 mile yesterday.
Gotta call blueprint engines in the morning........dayum........
I sure hope it's just a gasket. What a bummer.
Should I drain the oil and water, retorque the heads, and try again? Any chance the head just got loose? Or do I definetely need to pull the head?
Old 03-05-2006, 01:27 PM
jotto
jotto's Avatar
OUCH! I wouldnt do anything until you have called the engine company...if you followed all instructions then surely its covered by a warranty? If you start pulling parts they might turn around and say yah booh sucks, you pulled head etc, you voided warranty...no disrespect meant to engine company but here in Uk, if they can squirm...they will.
GOOD LUCK!
Old 03-05-2006, 01:38 PM
rcread
rcread's Avatar
I agree with jotto, and I can only imagine how hard it is not to tear into it right away to diagnose the problem. Step away from it, go to a movie, go to dinner, leave it until tomorrow.
Old 03-05-2006, 01:40 PM
MsVetteMan
MsVetteMan's Avatar
I think I'll go fishin', and maybe drown myself while I'm at it!!
Old 03-05-2006, 01:47 PM
rcread
rcread's Avatar
Yes, do go fishing. Drowning? Nah. Don't worry about it. It's probably some stupid little problem that's easy to fix. Maybe one of the head bolts that goes into the water jacket wasn't sealed properly. Maybe the heads weren't given a final torque. My money is on "no big deal".
Old 03-05-2006, 01:54 PM
cardo0
cardo0's Avatar
Default Slow down.
Milky oil is bad sign. But u can pressure test the coolant system without running the engine and then recheck wtr, oil, levels and colors.
I expect the damage is done if head not correctly torqued and don't expect anything from retorquing.
If not for the milky oil possibly only a freeze plug that's not sealing. Had a rear plug behind the flywheel do that leaked on my GTO after overhaul and the machine shop told me to drive it a while (was only a small/slow leak). Amazing mine finaly sealed itself. But it sounds like u have a fairly large leak and need to locate the source first.
As said before if eng still under warrenty then carefull not to dissasemble prior to return.
Sorry to hear the news.
cardo0
Old 03-05-2006, 02:39 PM
houstonvett
Support Corvetteforum!
houstonvett's Avatar
St. Jude Donor '09
Doesn't speak too highly of the Quality Control of Blueprint. Was the motor supposed to be on the Dyno to be checked out for problems such as you are encountering now? Good lesson for other forum members to learn from. Have the motor run on a Dyno before it is shipped. I am sorry you are the one this has happened too. I would make Blueprint replace that motor that you bought originally with one that was put on a Dyno first. Your time to repair their mistake or R & R a new motor should be worth something also. I'm lucky enough to deal with a good machine shop here in Houston that does take the time required to do things right. When you pay for a turn key motor it should be just that, turn the key and fire it up without the repairs. No telling what else might be wrong with the motor. Especially if the same amount of dillegence was used in assamableing the rest of the motor, houstonvett
Old 03-05-2006, 02:50 PM
MsVetteMan
MsVetteMan's Avatar
I couldn't stand it.......draining the oil (sludge of milky white coloration) now. Make take a while. I'm not going to pull anything except the valve cover off until I talk to them. Gonna drain the rad. and just see what I have.
The motor was "supposed" to have been put on the dyno before shipping and it looked like it was from the oil around the oil plug, and some water/antifreeze still in a couple of low spots. I am assuming nothing at this point. Will talk to them in the morning, and find out what I need to do. Don't want to pull the motor again after all that work I just went through.
It looks bad as this not just a light water mix. Dang oil is cream colored.
Old 03-05-2006, 03:25 PM
oregonsharkman
oregonsharkman's Avatar
I know how you feel I recently had the grey milshake experience myself.
Old 03-05-2006, 03:54 PM
MsVetteMan
MsVetteMan's Avatar
This don't look good, at all.......pics below....
Old 03-05-2006, 04:00 PM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
WoW!
Old 03-05-2006, 04:11 PM
MsVetteMan
MsVetteMan's Avatar
Doesn't look to good huh, jughead.........what ya think?
Old 03-05-2006, 04:17 PM
Yellow73SB
Yellow73SB's Avatar
St. Jude Donor '07
My uncles heads rusted through on his 600 bbc. This is really odd. They didn't leak when he drove but the next morning when he started it up water whould shoot out of the exhuast. Now he bought aluminum merlins.
big_G
big_G's Avatar
That's ... Hope you get that resolved quickly. Let us know what you find that caused that.
Old 03-05-2006, 04:19 PM
73jst4fun
73jst4fun's Avatar
WOW is right, I would not touch anything, take some photos on what you find and call them asap........sorry to see that
Old 03-05-2006, 04:23 PM
dgruenke
dgruenke's Avatar
Wow
Sorry to see that. They should give you a new engine AND install it for giving you that kind of mess.
Let us know what happens tomorrow.
Old 03-05-2006, 04:48 PM
Jughead
Jughead's Avatar
St. Jude Donor '09
You're in trouble. Who installed the heads?
To New crate engine is now a steam engine....bad problem...
Old 03-05-2006, 05:00 PM
Star79
Star79's Avatar
Holy crap! Looks like yogurt. Man.
I say tow to shop make them fix/pay for everything.
Old 03-05-2006, 05:03 PM
2th farmer
2th farmer's Avatar
CI 6-8-9 Veteran
Oh man I hope it's nothing bad.
Old 03-05-2006, 05:28 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
HOLY CRAP BATMAN...............dude you got to have the worst luck of anyone i know..........go drink some beers and pray for mercy.....i think i would be crying now if that happened to me....and looking for a c6
Quick Reply: New crate engine is now a steam engine....bad problem...
