2 Rear Wheel Bearing Questions
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Timken has a long and proud history of making quality bearings.
Some people feel they are among the best in the world.
I am one of those people.
Larry
code5coupe
Larry
code5coupe
Originally Posted by myblue91
1) Are Timken bearings any good? and 2) Who has used bearings from wheelbearingsinc. any comments on these?
Thanks for the reply's. I found some Timken bearings for $124.00 each, but if I could get them for half that at wheelbearings.com.....well who wouldn't if it's about the same quality.
Timken bearings are used on most freight train rail cars. Not that it has a direct correlation on Corvette hub bearings but, they know how to build a heavy duty bearing. Those rail cars can carry around 250,000 lbs each.
I will throw this out just as a thought, over the years (many) i have found that if you go to a industrial bearing supply shop and simply let them match part numbers,that 80-90% of the time you can save alot of money. Try it, it might save you enough to help you get the next thing you need. luck, ....
I have done that to replace old roller bearings and cages with modern sealed bearings on some of the systems on my 1948 Harley.
I don't believe that will help with the wheel bearings on a C4, since it is a hub assembly.
Mike
Mike
Thanks mike, i haven't looked at mine yet, but their on the spring check list, so now i know. and now i understand the price.
good bearings
i replaced the hubs on my car with timken bearings and i havent had any problems with them.....best i remember i paid 120 each for them from the local napa parts store as they were the only ones with them in stock same day....however it took me a week to get them changed.
