Z51 Rod End Grease DYI (pics)
Old 02-05-2006, 05:49 PM
Pipedreams
Pipedreams's Avatar
St. Jude Donor '06-'07
Default Z51 Rod End Grease DYI (pics)
No big effort here, but if you have the Z51 you should know about this. The manual does not show a location so it took a few minutes to find it.
From Manual:
"Vehicles with the Z51 performance package have
greaseable outer ends on both of the rear toe-links.
Under normal use, lubrication should be performed as
described in the maintenance schedule. See Scheduled
Maintenance on page 6-4 and Recommended Fluids and Lubricants on page 6-12. If you use the vehicle for racing, lubrication should be performed at the end of each racing day. "
Went to Pepboys and picked up a gun and a tube of Mobil 1 synthetic grease. You can get guns from $9.99 - $34 (I got the $34) the flex hose is a must unless you want to pull the tire.
They did a good job hiding it. It's actually tucked behind the rotor in the rear. It's not necessary to remove the tire if you have a gun with a flex hose.
Once the gun was primed I gave it 5 pumps
Old 02-05-2006, 06:12 PM
66dreams
66dreams's Avatar
Thanks!
Old 02-05-2006, 06:13 PM
Vet
Vet's Avatar
Excellent Ed! Nice! Thanks for sharing.
Ironically I just bought that same exact grease gun 3 days ago specifically for this purpose... nice unit. The local Pep Boys here did not have a good selection so I got my gun online... same price. Seems to be one of the best around for this purpose.
Actually, the gun I got is slightly different, but looks identical:
Lincoln Industries Pistol Grip Grease Gun, Model# 1134
Lincoln grease gun from Northern Tool
Old 02-05-2006, 06:17 PM
The Garage Master
The Garage Master's Avatar
As usual you are the man, Thanks.
Old 02-05-2006, 06:28 PM
yonglvnv
Support Corvetteforum!
yonglvnv's Avatar
Thank you, thank you, AND thank you.
Old 02-05-2006, 06:42 PM
clem zahrobsky
clem zahrobsky's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
From Manual:
that is because the heat from the brakes with track use causes the grease to be boiled out where this will not happen on the street
Old 02-05-2006, 07:09 PM
bigearl56
bigearl56's Avatar
Default Ed, "You Da Man"
Once again Ed tells us the things we need and want to "Know". He not only tells you how to do it, he tells you where to get the "Stuff". I just ordered and rec'd a set of splash guards from him. The directions are crystal clear.
Old 02-05-2006, 07:16 PM
northernplus
northernplus's Avatar
I have had one of those guns for a long time. Never a problem, and it doesn't leak any where. (Purchased at a PEP Boys.)
Old 02-05-2006, 07:22 PM
Pipedreams
Pipedreams's Avatar
What's your source of info in this one? First it's hi temp grease, second the boot is sealed. I could be wrong but IMO that can't happen ,that the link in free air could get that hot but yet, the paint on the rim and the grease in the bearings are OK. I would think the reason they recommend grease after track use it due to extreme load on the rod end. I could be wrong
Old 02-05-2006, 07:30 PM
ProfMoriarty
ProfMoriarty's Avatar
Where is the old grease displaced to?
Old 02-05-2006, 07:47 PM
clem zahrobsky
Cruise-In I Veteran
the C-5 burnt the boots off of the tie rods ends during track use from the heat. the rotors get red hot during very hard braking
Old 02-05-2006, 07:53 PM
sk1mcguire
sk1mcguire's Avatar
Default Pictures are indeed worth it!
Hey Ed!
Thanks for the great post. I tried to get some pictures on your last post relating to the Mobil 1 grease that was in the Tech section but there were no takers.
Is that the gun that needs to be attached to an air compressor, or just hand pumped? Also, is there a specific procedure or amount that needs to be applied into the toe link?
Thanks again for the timely and informative post!
Best Regards,
Jonathan
Old 02-05-2006, 08:00 PM
Pipedreams
Pipedreams's Avatar
Originally Posted by sk1mcguire
Hey Ed!
Best Regards,
Jonathan
Hand pump, I did five pumps but as soon as you see the boot expand I would stop.
Old 02-05-2006, 08:04 PM
clem zahrobsky
Cruise-In I Veteran
Hey Ed!
Best Regards,
Jonathan
do not over pressure the boots when you use the grease gun as they can come loose or even rupture.
Old 02-05-2006, 08:12 PM
Jimbeaux
Jimbeaux's Avatar
Nothing better than a well greased Rod End I always say...
Old 02-05-2006, 08:56 PM
burtonbl103
burtonbl103's Avatar
St. Jude Donor '06-'07-'08 & '12-'13
Man ed your car looks great but you should soak your rotors in some oxysolve !
http://forums.corvetteforum.com/show...7&forum_id=101
Old 02-05-2006, 09:14 PM
sk1mcguire
sk1mcguire's Avatar
Default Clear and consice!
Thanks again Ed! I'll make a lunch run to Pep Boys as I already have the Mobil 1 tube ready to go.
I'll tread lightly on my first application -
Jonathan
To Z51 Rod End Grease DYI (pics)
Old 02-05-2006, 09:16 PM
sk1mcguire
sk1mcguire's Avatar
Default Copy that as well!
Hey Clem!
With the same advice from you and Pipe I'll take it easy on my first application. The last thing I need is to louse up my rear!
Thanks a bunch - Jonathan
Pipedreams
Pipedreams's Avatar
Why? when the wheel is on you see nothing, besides most of the rust you see is on the hub.
Old 02-05-2006, 10:29 PM
tschux
tschux's Avatar
We are all very fortunate that you are a member of this forum.
Tim
Quick Reply: Z51 Rod End Grease DYI (pics)
