Magnaflow muffles 14336 installed
Last week I had 2 Magnaflow muffles, model number 14336 installed on my 2005 C6. Cut off stock mufflers at the inlet. Cut off stock tips at the outlet. Weld stock tips on the Magnaflow mufflers. Weld new mufflers at the orginal location
Install pics and before/after videos here
Get Some!
Originally Posted by doje
Wrong forum
I like that sound - nice looking job.
Originally Posted by MAJ Z06
Not necessarily. He's not asking a tech question or presenting a tech how to; he's just showing off his new pipes, that is done a lot here in General.
Originally Posted by Skatduder
Sounds great. But how is it inside while driving. Can you hear your tunes ?
Originally Posted by Jagcvette
How do you like the sound, is it deeper then Corsa's?
Originally Posted by Big duke
Homer,Looks to be a muffler clamp on the magnaflow?Or is that just holding in place to be welded?
They actually used both. They tack welded it, and then clamped it. Not sure why they decided to use both.
Magnaflow Exhaust
Sounds good but the stock pipes are small and the Magnaflow tips are larger and fill in the area making it look better and the sound is great. Guess if you want the stock look with a better sound it is ok.
