[Z06] Dyno Number at 427 Miles! Morressey was the Builder.
Just returned from DYNO at Speedtek Performance...here are the RESULTS:
First Pull - Air Filter Removed CF: SAE Smoothing
RUN TYPE: RO
RUN CONDITIONS: 75.49 DEGREES F
29.28 IN-HG
HUMIDITY: 10%
SAE: 1.00
469.39 RWHP
Second Pull - Air Filter Installed CF: SAE Smoothing
RUN TYPE: RO
RUN CONDITIONS: 75.45 DEGREES F
29.29 IN-HG
HUMIDITY: 11%
SAE: 1.00
459.72 RWHP
MAX TORQUE: 432.44
The elevation is 615'.
Dynojet Dyno
RUN TYPE: RO
29.28 IN-HG
HUMIDITY: 10%
SAE: 1.00
469.39 RWHP
RUN TYPE: RO
29.29 IN-HG
HUMIDITY: 11%
SAE: 1.00
459.72 RWHP
MAX TORQUE: 432.44
Dynojet Dyno
RUN TYPE: RO
29.28 IN-HG
HUMIDITY: 10%
SAE: 1.00
469.39 RWHP
RUN TYPE: RO
29.29 IN-HG
HUMIDITY: 11%
SAE: 1.00
459.72 RWHP
MAX TORQUE: 432.44
Dynojet Dyno
RUN TYPE: RO
29.28 IN-HG
HUMIDITY: 10%
SAE: 1.00
469.39 RWHP
RUN TYPE: RO
29.29 IN-HG
HUMIDITY: 11%
SAE: 1.00
459.72 RWHP
MAX TORQUE: 432.44
Dynojet Dyno
Thanks Henry
