Pre-cut Insulation Kits @ Exotic Vette
Premium Supporting Vendor
Location: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
$25 off on our pre-cut insulation kits! More info available on our webpage: CLICK HERE
$210 shipped!!
Save time with our kit being pre-cut, includes instructions with pictures and diagrams. Full kit is lightweight (approx 5lbs) and will give you a dramatic reduction in cab heat and noise.
Literally hundreds of forum members with this kit
$210 shipped!!
Cruise-In VIII Veteran
About to pop for ...
a full kit for my coupe.
One Q: How effective is the kit in reducing noise coming in from the wheel wells (i.e., ahead of the rear tires)? Trying to figure out whether I'll also need to stuff some insulation up into the area above/in front of the inner wheel well liner while I have the car apart.
Thanks, Dan!
Mark
Thanks, Dan!
Mark
Great kit. If you are an audio guy combine this with some sound deadening in your doors and rear cargo area (if you have a sub) and you will make a BIG improvement for not much weight added.
Fej
Fej
Cruise-In V Veteran
Thanks, Dan!
Mark
Thanks, Dan!
Mark
Cruise-In V Veteran
Originally Posted by FactoryRaceCar
How much for the half kit (just the front) shipped?
How well does just the rear half kit work? I don't really want to pull my seats, etc. but I would like a little bit of quiet inside. Car is '02 Z06
Cruise-In V Veteran
Email me and I will send you the install files by email. The front's really not that hard at all. Worth doing the entire car. If you're spending a few hours of your day why not spend a little more and get it done all the way? Helps either way, but the more you cover the better.
I just finished doing my 02 coupe but haven't had a chance to drive it due to weather and other mods. The rear is SOOOO simple to take stuff out and put back. The front isn't that hard honestly if you have ever done anything mod related in your life. The toughest part is probably just taking the seats in and out if you consider that hard.
This kit is soooo fricken cool. I did dynamat extreme and it cost me more plus probably ten times the labor, time, beer, and cussing! I wish he had them for suv's
Former Vendor
St. Jude Donor '06 & '12
$210 shipped!!
$210 shipped!!
Jeff
Cruise-In V Veteran
Couple ways to order for the discounted price. You can call us 407-221-8040, you can paypal directly to us at sales@exoticvette.com, you can pay by the website and make sure to put a note in the msg area about the discount and I will send the difference refund back to you asap, or you can mail a check or post office M/O.
Dan
Dan
Cruise-In V Veteran
firemanrandy and z06worshiper Thanks for the comments!
If I was to get this would I beable to get an extra pice to go under the dash area around the shifter and under the radio area? Or is that included?? I couldnt tell by the pic.
Thanx
Nate
Thanx
Nate
Former Vendor
Dan
Dan
Thank You Sir
Jeff
The full kit is really only 5 lbs? I find that hard to believe. Can anybody verify how accurate that is. I wouldn't mind adding some sound and heat insulation if it only added like 10lbs or less.
Location: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
