[Z06] TPS Report from the Field
I mounted my track tires which have a new set of TPS sensors, but DID NOT reset the car to those sensors. Then I set off on an 80 mile trip to Willow Springs. At about 30 minutes into the trip the DIC displayed a TPS system warning message. Hit reset, and the message disappeared, and did not reappear until I restarted the car after reaching my destination. Reset and the message disappeared again. However, while TC could be disengaged, AH could not be disengaged nor could the car be put in COMP mode. I then did the TPS reset with the radio tool, and all was well with the TPS system. My Z is a fairly early model (VIN 005xx).
The only variable I'm not sure of is whether the presence of an unrecognized set of sensors caused the car to go into a deeper mode of protection than would have been the case had there been no sensors at all. I don't know. But I do know that the car could not have been driven at the track without going into COMP mode or turning AH off altogether - R compound tires and full AH mode will not cut it at Willow Springs.
Another bit of the puzzle . . .
Originally Posted by vettemaster1
very interesting....when my warning came on and i pushed reset i was able to take off ac/tc and go into comp mode.....[ no sensors in my wheels]
Originally Posted by allanlaw
I knew you would be interested in this. The implication of the existence of an unregistered set of sensors causing a change in the way the car handles the TPS warning means that the car could be affected by TPS sensors on another nearby vehicle. You may remember some time ago when I passed along a report that a Corvette driving school thought its C6 cars without TPS sensors were being affected by sensors on students' cars. This was thought to be highly unlikely. I still doubt it. But that doesn't answer the question as to why your car and my car seem to be of unlike minds . . .
I would guess that the designer of this feature is using it for a safety device due to the power of the vehicle.I would also think that if one tire was way out of wake that at high speeds it could make a very unstable situation.But I am no expert!
ok...so how did u like the car with race rubber at the track?....i have a race next weekend...i will make sure to drive far enough to get the code to set and then double check that i can get into comp mode and turn it all off mode!!
Former Vendor
Did I read correct, wheels without any sensors installed can turn of AH and go into Comp. mode?
