[Z06] Can anyone confirm the wheel offsets for me?
I've seen some specs on another site that are supposedly the stock wheel offsets and just need to confirm that. I'm getting ready to order some custom wheels ($$$) and want them to be identical to the stock specs.
Here is what I have seen. Does anyone have their wheels off so that they can double-check these numbers?
18"x9.5" fronts (offset +40)
19"x12" rears (offset +59)
Any help is much appreciated.
Originally Posted by Cobra4B
You can tell me that in person at the Cruise In this year. I'm going.
Did you have to put down the on the Mrs.?
CI 3-5-6-7-8 Veteran
Back on topic... is that 24k gold or 14k gold on the new rims>
Z06 Wheels
I am going with Radical Wheels. They are just like the polished wheels from GM, but they are triple chromed.
Originally Posted by donkt
2K1 vette - the standard wheel offsets are, front 56 mm, and the rears are 79 mm.
C6 Corvette Chrome C6 Z06 Set (2-18x9.5 & 2-19x12)
Set of 4 Chrome C6 Z06 Style Wheels for True Z06 C6 Corvettes.
These triple chrome-plated wheel castings are CNC machine-finished then pressure tested for structural integrity, lateral run-out and concentricity. Includes matching chrome center caps and lugnuts. Comes with a 36 month Factory Limited Warranty. Offset +40(18") and +59(19") Wheels accept sensors.
It looks like the offsets you mentioned are for standard C6 sizes and NOT Z06 sizes.
C6 Corvette Chrome C6 Z06 Set (2-18x8.5 & 2-19x10)
Set of 4 Chrome C6 Z06 Style Wheels for Standard C6 Corvettes.
These triple chrome-plated wheel castings are CNC machine-finished then pressure tested for structural integrity, lateral run-out and concentricity. Includes matching chrome center caps and lugnuts. Comes with a 36 month Factory Limited Warranty. Offset +56(18") and +79(19") Wheels Accept Sensors.
I'm pretty sure the offsets I originally quoted are correct, I just want independent verification of that.
Z06 Wheels
2k1 vette, I am sorry, when I looked at the wheels when Radical Wheels first came out with the chrome ones, the offset was 56 and 79. I went to the site that you had and they have changed the offsets. You are correct.
