Best Vid. Camera for Track?
I'm thinking of buying a video camera (and rollbar mount) pretty soon and want some advice. I've been watching some in car video from friends and also just random stuff I found online (gotta make it through the winter somehow) and decided I'd really like to start taping my AutoX and Track Days.
The first thing I've noticed in almost all the videos is that the view is too narrow. I know that in my friends' videos they had the cam "zoomed" all the way back/out so there was no way for a wider shot. Are there any vid. cams out there w/ a special panoramic view or anything like that?
Secondly which cam has the best "steady shot" type of feature? Obviously there's a lot of vibration and bouncing around during a AX or RR lap and no camera is going to be perfect... but the smoother the better.
What are you all using? Likes? Dislikes? Have you seen some film from a particular camera you really liked? Etc?
Thanks.
-TJ
Thanks.
-TJ
Best thing to do is get all of the recommendations from here and then go to a Best Buy/Circuit City/ or upscale camera store and check out the different ones first hand.
There are wide angle adapters made for some of the video/DV cams. The biggest problem with them is that they don't replace the existing lens but mount over top of them. I haven't seen one used on a DV cam so I'm not sure how good they are.
you'll need a wide-angle lense, available from most camera shops. It simply screws onto the camcorder. Get a camera with a short body (height, not length), and the lense mounted low. This helps with vibration on IOPort style mounts.
get this
not something like this
get this
I have a 4 or 5 year old Sony with the Hi8 tape works great and wide lens was about 60 bucks from Sony. I bought a new Sony disc camera but I tried it twice and it shut off after a minute or two. Works great otherwise. Not sure if the vibrations bother the disc camera. The old one has traveled every track mile I've done with no problem.
Sony has an "Excellent" Steady Shot feature.
I also have a Sony digital 8 cam corder. this was... state of the art... way back in 2001. This camera has stood up to years of track abuse and is still going strong.
I also have a Sony digital 8 cam corder. this was... state of the art... way back in 2000. This camera has stood up to years of track abuse and is still going strong.
Received 8,951 Likes
Bill
St. Jude Donor '07
Getting a good camcorder with the proper inputs is important, but not as important as the right camera. I find that camcorders do not have a wide enough view angle for most in car applications and wouldn't you like a small light weight camera that you can mount any where inside or outside the car and plug into your camcorder? Why limit yourself with inside shots!
Chase Cam
"Now with 580 lines of crystal clear resolution"
The BulletCams are very small, lightweight, and rugged.
Because of its low weight, there's less "mass" undergoing shock and vibration which means a more stable image, higher reliability and less chance of damage. It also opens up the use of smaller mounting methods so that you can mount the camera when there's not much space available. For maximum reliability, the camera is a single printed circuit board with surface mount components and a board mounted CCD.
The BulletCam is weather and waterproof. You can even submerge it (up to 10 feet, with a waterproof cable).
Our BulletCams use a wide-angle, lens which is ideal for motorsports. Many lenses are too narrow and the field of view just doesn't capture the excitement and vividness that you get with a wide angle lens. You can also get too wide an angle. We can supply our cameras with 90 or 120 degree lenses and lenses can be swapped out.
The camera is mounted in a hard aluminum tube with standard camera mounting attachment points. The front is a replaceable protective lens. If the front protective lens is damaged, it is easily replaced.
Lots of different mounts. They also have other recording devices you can use besides a camcorder.
Nice little video of a shifter kart in action...
Nice tire cam view!
Chase Cam
Nice tire cam view!
Moderator
Received 3,072 Likes
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'12, '14-'15
Yup that is what I have as well...video is great
Cruise-In III Veteran
Sony DVD handycam, mounted on 1/2" of foam on RD crossbar camera mount. No issues, great video, and super easy replay. Just pop in the disk and go.
Another advantage of the Sony is that it has a LANC input which allows you to use a remote button to start and stop recording. I will be switching from my Panasonic for that reason. If anyone is interested I will be selling my Panasonic MiniDv w/ wide angle lens, spare battery and case for a reasonable price. It is only 1 year old and in excellent condition and takes great videos.
Thanks, Scott
Thanks, Scott
Thanks, Scott
Thanks, Scott
I'm leaning way more towards the BulletCam type of idea though.
-TJ
PS- Thanks for all the great input folks!
Get a camera that allows side loading of the tape. That eliminates having to dismount the camera each time you want to change tape. On my Sony IP55, that's a PITA, not that hard, but I'd just as soon not have to do that.
Wow... after spending some more time on ChaseCam's site I'm about to spend waaaaaaay too much $.
I'm looking at buying two of their bullet cams, their Picture in Picture box and their capture box. I want to record stuff like this: http://www.chasecam.com/ss/061105run7a.mpg
They also mention a G-Meter that you can add-on to the capture box that will display Gs on the video as well. Hmmmm... I already emailed them to see if I can get some sort of package deal on everything.
-TJ
-TJ
