Check out my in car PC/DVD/Audio upgrade install.
Old 12-19-2005, 12:23 AM
eitspc5
eitspc5's Avatar
Default Check out my in car PC/DVD/Audio install (PICS).
I was inspired by Scott_FX
Nor sure what the deal is, maybe the flourescent lights, but the carpet match is not as off as it appears in these photos
Center Channel...Just thought it looked cool ..
More can be found here:
http://www.ittoyou.com/pics/foldervi...older=Vette+PC
and here:
http://www.mp3car.com/vbulletin/showthread.php?t=65647
Old 12-19-2005, 12:48 AM
NAVY08
NAVY08's Avatar
St. Jude Donor '06-'07
wow that looks great i wish i could do something like that, its sure on the list of things to do
Old 12-19-2005, 01:07 AM
JTS97Z28
JTS97Z28's Avatar
what did you use to re-do the center console bezel? the texture and color looks perfectly factory. I am needing to do mine since I added the Avic-D1 navi.
Old 12-19-2005, 01:13 AM
Icemanskis
Icemanskis's Avatar
Cruise-In VI Veteran
St. Jude Donor '05
The faceplate you constructed for the nav screen looks top quality. One of the nicest setups I have seen here.
Old 12-19-2005, 01:20 AM
edensknight
edensknight's Avatar
Holy Smokes, Batman! Awesome!
Old 12-19-2005, 01:23 AM
FactoryRaceCar
Support Corvetteforum!
FactoryRaceCar's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old 12-19-2005, 01:24 AM
eitspc5
eitspc5's Avatar
Thanks guys.
I am accused of being a bit of a perfectionist, but to me its not quite perfect. Here is how I finished the modified bezel.
I sanded and filled the location where the piece was cut with ABS filler (ABS shavings and acetone), and bondo spot putty. Then I used SEM texture pray to throw a little texture back over the spots and sanded a little. I finished with dupicolor flat black vinyl and fabric paint.
I ran into problems with the painting. I wanted to keep the original texture, so I could not sand the whole piece. When I painted I got some crackle effect in a few spots I had not touched. These had to be sanded and repainted, I think due to contaminents in the plastic. I did repaint the entire peice to match.
I think I would recommend sending it off to get re-textured. I know SCOTT_FX sent his off and got it done for ~$65.00 or something from leather magic and it looks awsome.
Old 12-19-2005, 06:42 AM
AFVETTE
AFVETTE's Avatar
Sweet, I wish one of our vendors would manufacture a modified center stack section for us less skilled folks. I'm afraid I'll be forced to see my Z and buy a C6 just for the ability to add an aftermarket NAV system.
Tom
Old 12-19-2005, 06:52 AM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Very well done. It looks like a clean and professional install. Man, I'd love to do something like this. Awesome job.
Paul
Old 12-19-2005, 06:59 AM
GB Vette
CF Over the Hill Member
GB Vette's Avatar
Cruise-In IV Veteran
CI-4 Car Show Winner
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
Awesome Love the 8" monitor and the center channel
Old 12-19-2005, 08:30 AM
b98
b98's Avatar
Old 12-19-2005, 08:39 AM
StuzVette
Cherish your Hopes...
StuzVette's Avatar
Well done...
Old 12-19-2005, 08:44 AM
RobBob
RobBob's Avatar
Man all these car PC threads are killing me. I want to do this so bad.
Old 12-19-2005, 08:55 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Excellent workmanship, you should be proud.
Old 12-19-2005, 08:56 AM
DeeGee
DeeGee's Avatar
Outstanding job.
GM could have had an awesome fit on the C6 if they'd looked here for inspiration.
Old 12-19-2005, 09:02 AM
0Z06Joe@AutoBuffs
Former Vendor
Z06Joe@AutoBuffs's Avatar
St. Jude Donor '08-'09-'10
Looks great!!!
Old 12-19-2005, 01:30 PM
TheLaserShop
TheLaserShop's Avatar
I would seriously like a parts list on that setup. Can also laser cut a bezel. Textured ABS (I think that is what you have) and whatever mounting pads..
edit: Saw the parts list on MP3car forum. What is the approximate cost?
To Check out my in car PC/DVD/Audio upgrade install.
Old 12-19-2005, 02:37 PM
eitspc5
eitspc5's Avatar
Lasershop,
I am into this for ~$2300.00, the audio stuff was $750 of it, power another $250, monitor $400. I definately could have saved some money on the PC if I shopped around, also a small low power unit may be more practical, time will tell.
I did this install with a dremel, drill, hand tools and no room to work . A laser cut bezel would be awsome. My lines are far from perfect and if you look at the back, its basically pieced together and epoxied.
With the right tools and a workshop, this would not have been a bad project. With what I had to work with, it was a bit of a pain, but still worth it.
Old 12-19-2005, 03:13 PM
Sportsdude
Sportsdude's Avatar
Wow, awesome work!
Old 12-19-2005, 03:20 PM
TheLaserShop
Default Barter...
Tried to PM but you are full up. So Ill do it here.
Textured ABS we can get looks like wrinkle finish paint. Be happy to make you what you need if you are unsatisfied with the current bezel (looks great I think). Or we can make it out of any plastic. You just need to supply a good drawing with dims. I would trade that for a detailed list of parts (the cheaper way would be better, prices and where to obtain) and some instruction. I have Audiobahn amps already and a full compliment of kickers. Let me know if you are interested.
P.S. We cant laser cut metal at all. Don't have that kind of power. Either way, I really appreciate the craftsmanship.
Thanks, RonO
Quick Reply: Check out my in car PC/DVD/Audio upgrade install.
