truck button
Mine stopped working for about a week and then started working again. That was about last may. Some have reported getting dirt/corrosion in the switch and had it replaced.
It only takes a few minutes to remove the switch by reaching in once the inside passenger side tail light is removed. The reason I repaired it myself is my local service tech wanted to drill out the bracket to remove the switch. That would not have worked and would have destroyed the holder for the switch.
Originally Posted by S22C6
Your dealer will replace the switch under warranty
As he did mine and many other people on this forum.
Member Pipedreams has an excellent write up on this posted here. In my case the dealer would have caused more damage than they repaired with this simple fix. If you let your dealer replace it make sure that they know how to access the switch. I have heard of some removing the entire rear section to gain access.
In their defense they did not have a C6 tech but were trying to help me instead of having to drive over an hour to a dealer with a C6 tech.
Got 114 miles on the car and the remote trunk unlock works irratically. Good to know (I guess) that I'm not alone. Thanks for posting. I'll just add this problem to the list when I take it in for the FIRST oil change.
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08-'09-'10-'11,'22-'23
you know that key that they gave all of us works on the trunk also.
