TSB on differential groan in C6's
Is there a TSB on the differential groan that occurs when turning the car (especially cold). If so, the number would be appreciated.
Thanks,
Jimmy
Thanks,
Jimmy
Former Vendor
St. Jude Donor '13
You only want the #?
Rear Axle Chatter Shudder on Turns - keywords differential fluid noise oil #PIP3559 - (Sep 22, 2005)
1999-2006 Chevrolet Corvette
2004-2006 Cadillac XLR
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Rear axle chatter or shudder on turns on Chevrolet Corvette and Cadillac XLR.
Recommendation/Instructions:
If this is the first complaint for this condition flush and fill the rear axle with P/N 89021669 (in Canada 89021670) gear lube and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
If this is a repeat complaint or the condition persists after the flush and fill, replace the right and left rear axle clutch packs following published service procedures.
After clutch pack replacement use 1.6 l (1.69 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455). and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
Note: 2006 Z06 equipped vehicles require 2.55 l (2.70 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 190 ml (6.4 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Note: Export vehicles use 2.01 l (2.12 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 150 ml (5.1 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Once the axle fluid has been changed the car must be driven in 8 - 10 SLOW figure eights to work the fluid between the clutch plates.
Condition/Concern:
Condition/Concern:
Condition/Concern:
You are quick on the response and thanks for getting us this information. Do you know if this occurs only on manuals as I experienced it with my A4 yesterday when the temperature is about 30 or below.
Thanks in advance,
Jonathan
Thanks,
Jimmy
Thanks,
Jimmy
Is that what I'm hearing?? I thought it was my hard Z51 tires slipping on lock turns!
Thanks!
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Cool info. So far, I'm only at complaint level #1, and that is exactly what they did for me. Well, they diagnosed it as viscosity breakdown of the diff gear fluid, which seemed very odd at less than 9,000 miles.
The most notable place I heard it was as I was making slow turns in parking garage.
Cruise-In V Veteran
Originally Posted by sk1mcguire
... Do you know if this occurs only on manuals as I experienced it with my A4 yesterday when the temperature is about 30 or below....
Hello GTC,
Thanks for the information reagarding your A4 and similar symptoms. I never noticed in the warmer weather or maybe I just hadn't made a tight turn since now! I'll keep you posted on my local dealership and the repair process.
Keep in touch!
Jonathan
Keep in touch!
Jonathan
I noticed this when starting out from a dead stop at a light and then turning right and punching it. It felt like the right rear hopped over something or hit a big pot hole. Mines an 02 C5 But I don't care, cause Kevin just sent me my Vin for my Monterey Red Vert. If it does it I'll let everybody know. The dealer didn't have a clue and said "couldn't find anything.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Happened on my A4. Had it almost since I got her new. Replaced the fluid myself and added the GM friction modifier and no more problem. My car has only 8700 miles now. Started noticing this in September.
Any special type of ATF or just the GM recommended? Also, what is the friction modifier?
At your convenience!
Jonathan
Hello ByByBMW!
Jonathan
Jonathan
OBTW, there are quite a few Amsoil users who say you don't need the GM stuff with their gear oil. I tend to agree but I used it anyway, can't hurt. Only issue is some people say if you use to much of the GM additive, your diff may not lock up as well as it is supposed to. Only a big issue when racing the car as far as I am concerned.
Hope this helps.
Premium Supporting Vendor
... The bottle is about 4 ounces if I remember right. Just the right size for our diffs.
Hope this helps.
Hope this helps.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Here are some helpful TSB sites:
http://www.batauto.com/main.html
Another one, that will provide feed back:
http://www.troublecodes.net/technical/
Cruise-In V Veteran
Now that somebody else ttt'd it, I took my C6 into the shop for complaint level #2 yesterday. Just a tick over 11,000 miles on the odo, which is slightly more than 2,000 miles from when I brought it it for complaint level #1. At first they said that they couldn't reproduce the sound. I gave them a more detailed description of how to get it to misbehave. They tried again, and failed to. So when I went to pick it up, I took him for a drive and pointed out when it was making the sound. Then he had his main technician take a ride with me, and he heard the sound. The technician was saying that GM won't let them replace the clutch packs, that they'd have to get an entire new diff gear. They suggested that we do just a diff gear fluid change again. They said that they would call me back today, but they didn't.
This car is a nightmare.
GTC, you need to stop it with these problems. Every time you get another one, so do I. I have noticed a crunching sound when making slow almost full lock turns. Something to report tomorrow when I take mine back for the top recall. It's a good thing I'm retired or I would be using all of my vacation time at the dealer. I'm still trying to like this thing, it's a good thing that it was never my dream because it's quite the nightmare.-Ed
