One of the Best Threads ever posted Newbies must read
Old 12-04-2005, 09:31 AM
David426
David426's Avatar
Default One of the Best Threads ever posted Newbies must read
I found this the other day in one of my saved files. It was posted quite some time ago by another Forum Member. I thought I would repost it for the newer members. This is the most informative thread I have ever seen posted Put it in a saved file for you personal use.
This thread is an evolution of a couple old threads, and topics that come up over and over and over again. I’ve compiled most everything I know into this one thread. I’m always expanding and correcting this information; if anything is incorrect or missing, please post and point them out or PM me. I know I’m extremely fallible, yet humble, so feel free to shred this post to shreds, but do it constructively. As many of you have surely noticed, I’ve posted up lots of garbage in the past, but I’ve learned and will continue to learn. Because of the constant updates, posts down the road may get confusing, but just remember the information at the top is my latest and greatest. Enjoy!
Common Problems
Leaking Battery
Many C5's came with AC Delco Freedom batteries that had a tendency to have it's case crack open near the battery posts. The leaking battery acid would drip down the side of the battery, down the funnel-like battery support, straight down onto the PCM and the wiring loom. It can also get onto the A/C lines. I believe they are the vacuum lines that control the movement of the interior vents, and usually the system will default to blowing out the defroster vent. Sometimes car crippling damage would occur, sometimes not. It worst it would mean replacing the battery, the PCM, the wiring harness, grinding the rust off the frame to repaint it, changing the A/C lines and possibly swapping out another computer as well. This mostly happened on early C5’s because later C5’s used a gel-type battery that cannot leak, but I believe the problem resurfaced on ’04 or ’05 models again.
Check this out on any car you look at. Use a 8 mm monkey wrench, preferably a ratcheting closed-end version, to removed the battery cables. You also remove a holding block on the front side of the battery. You will need a long extension to reach it. The battery basically lifts right out. Also remove the black plastic battery tray. Look beneath the tray for rust or white powder. Signs of both are evidence of battery acid damage. It would probably be best to move to the next Vette unless you don't mind possibly tackling this repair in the future. It's possible that the car will throw codes for no apparent reason.
No matter what Vette you buy, just make sure you replace the battery with a gel-type battery, like the Optima Redtop, sold at CostCo for $100.
Grounding Problems aka CRAZY electrical gremlins!
Bill Curlee has a great thread on the problems that corroded ground connections can create, and how to clean out the grounds. The most problematic ground connections are behind the headlights on both sides. Check out Bill’s thread for detailed info: Go!
Here’s where all the grounds are: Go!
Water Intrusion
Water leaks have several ways of getting in the car, and none of them AFAIK are very difficult to fix. Proper adjustments and maintenance will prevent most leaks.
Bill Curlee’s thread abouting locating & cleaning the udders, and sealing the door hinges.
Here’s a few TSB’s from the CorvetteActionCenter.com:
1997-1998: Service Bulletin: Waterleak Above Door Glass (Reseal Blowout Clip)
1997-2002: Service Bulletin: General Waterleak Guide
1997: Service Bulletin: Water Drips into Rear Compartment After Hatch/Glass Has Been Opened
Seats
Corvette seats are delicate.
Sliding hard across the bolster can break it, causing it to flap side-to-side.
The leather is cheap, and there's little protection for it. It will wear out and form cracks, which is normal…for cheap leather.
The wire springs in the seat bottom, and the bars in the bolsters can also wear thru the foam and leather, but that can be fixed by placing layer of burlap between the springs and the foam.
Check the black plastic surround on the bottom of the seat to make sure it fits snugly against the leather, and isn't cracked. Older style plastic surrounds had a tendency to separate from the seat, but could be pushed back in. The newer style plastic surrounds can be used as a direct replacement, but one of the plastic studs may need to be ground off, or a hole will need to get punched into the leather.
The seats tend to rock back and forth by about a 1/4" during acceleration and braking. It can be fixed, but GM will not fix it. Some lucky owners can get the dealer to replace the frame under warranty. The seat backs swinging forward under braking is normal, and not considered a problem.
Here are a couple fixes:
Corvettemechanic.com --- must be a member
Rocking Seat Fix
Seat choice
Get the sport seats. The sport seats have a hole under the headrest. Some people put racing harness belts thru those loops. The seat frames and foam in both seats are interchangeable. Harness belt holes can be installed using Ford harness cutouts. Ask the dealership for them, they should know what it is without a part #. The foam in a standard seat will need to be cut, and sewing will have to be done, but it’s an easy job.
Headlight bezel plugs
There are 1-1/2" plugs that are located on the headlight bezels that would fall off on the older Vette's. The new style plugs, have a twist-lock to prevent them from falling out, but also requires new bezels. Only the new bezels & plugs are available now, and they are compatible with older C5’s.
Headlight gears
The gears in the headlight motor are plastic, and wear out over time. Ice, heavy Euro or projector headlights and twilight sentinal will cause the gears to wear out quickly. Fortunately a few years ago, Rodney started selling replacement brass gears, check out his website. Corvette America and probably a few other vendors now sell their own copy of his brass gears. Here’s a thread that shows how to replace the gears.
Roof noises
If you buy a coupe with a removable roof, you can expect wind noise and some creaking. The wind noise will never totally go away, but if there's creaking, you can eliminate that by thinly applying dielectric silicone grease to the weather-stripping. It also prevents cracking, so do this to all weather-stripping, on any car.
Hood rattles
During cold weather the rubber hood stops can also rub and rattle against the hood. Adjust and lubricate the rubber stops so when you pull the corner of the hood up, it doesn’t pull up, but the hood still closes.
Drivetrain rattling
The valvetrain makes a significant amount of noise at idle. It may sound like sewing machine. Converting the valve rockers to true shaft-mounted adjustable roller rockers with may help eliminate the valvetrain noise if adjusted properly. Installing a big cam and stiffer valve springs will make the noise louder.
On manual transmission cars (M6 or M12), the transmission sounds like it is rattling when leaving the line. It is normal. It is the clutch throwout bearing rattling around. Sometimes you'll hear a horrible rattle if you shut off the engine. If you press the clutch pedal in while shutting off the car, you won't hear it.
Shaky breaking
The front brake rotors warp easily under heavy braking…or at least that’s what uneducated drivers think. I tend to believe StopTech: http://www.stoptech.com/whitepapers...rotors_myth.htm
I verified this by lightly grinding my rotors with steel wool. Garnet paper is recommended, but I haven’t tried it.
If you insist the problem is warping, don’t turn the rotors since thinner rotors warp more easily. Resurfacing the rotors is only a temporary fix, one that is less effective each time your resurface the rotors due to the reduced thermal capacity of the rotors. Rotors are available for $25 at Napa and RockAuto.
Scraped front ends and rocker panels
Checking for scrapes is an easy way to tell if the car was treated well. It's almost impossible not to scrape the front end, but there are two metal crash bar loops that should prevent the bumper from scraping. The bumper itself should not have scrape marks on it. Check the underside of the tip of the bumper, and the bottom corners of the bumper. If the crash bar gets scraped enough, eventually it will wear down to the point where it needs to get replaced. It costs about $220 for the crash bar, nut-serts, bolts and insulators, and can be replaced in a couple of hours, just be sure to hook the hoses and electric connector back to the A.I.R. pump.
Here’s a list of ALL the parts you’ll need to replace the impact bar and the side air deflectors:
Part #------Qty---Description
10188023---001---Insulator (goes to bottom of radiator)
10278679---001---Insulator (goes to bottom of radiator)
10278679---005---Nut
10400765---001---Plate (the actual impact bar, unpainted)
10419312---001---Panel (air deflector)
10419313---001---Panel (air deflector)
11515638---010---Nut-speci
11515757---010---Bolt-Metr
10281487---010---Nut
Not all of these parts need to get replaced, and there will be a few leftovers, but it will get the job done.
The rocker panels tend to get scraped on lifts and big speed bumps.
A & A Corvettes invented two products to prevent damage from both kinds of scraping. They have wheels that attach to the crash bar, allowing the car to roll on driveways instead of wearing down the crash bar. It will still scrape the spoiler, but the spoiler is a cheap wear item that takes only 2 minutes to replace without a lift or jack. They also make two aluminum strips that attached the frame next to the rocker panels, and they take the scrapes themselves instead of the rockers panels. Neither of the devices are visible unless looking under the car, and they are discreet enough to possibly be missed anyway. If you see these devices installed, you can be pretty sure the owner took good care of the car. Without this extra protection, you can expect to replace the crash bar and repair the rockers several times over the life of the car. WARNING: It won’t stop all scraping damage, just reduce the possibility of it happening, and reduce the damage when it does happen. Low hanging headers will probably still scrape.
Hood seal weather-strip
The sides and back of the hood compartment have weather-strip installed from the factory. The front is left open. Many owners install weather-strip along this front edge. You may not even notice it since it looks identical to rest of the weather-stripping. This extra weather-strip helps keep the engine compartment clean, and may also help the air intake system work better. This is another sign that the owner took good care of the car. The engine compartment stays pretty clean, but this the "extra step".
A/C System
There are two kinds of climate controls. One is manual with *****, and the other is a dual-zone electronic system. The dual-zone system did cost more, but is not as reliable as the manual system. A leaking battery can affect both systems. A strong system is when the vents cannot be switched.
Over time, and especially in humid climates, the system can cause condensation to leak onto the passenger side carpet. There are three udders under the driver’s side cowl. There are slits on the bottom, much like real udders. Vigorously squeeze and massage the udders until the debris has fallen out. Stop laughing!
If the vent settings cannot be changed, the vacuum line is probably loose, clogged or broken. Read more!
Squeaky steering wheel
When you turn the steering wheel, you may hear a squeak. It's just the plastic surfaces rubbing against each other. A shot of lubricant fixes this.
Squeaky/chirping/grinding wheel bearings
Drive slowly, better yet, coast along at low speeds with the windows open in a quiet location. Listen for a squeak from the wheels. Try turning in different directions. If you hear the rear wheels squeaking, you may have a worn wheel bearing. A replacement bearing costs $600 list, but you can usually find it for $400-450. I've heard that AutoZone has a better replacement for $126 by a company named Timken. The part is easy to replace if you can separate the ball joints. I had to buy a special Kent-Moore tool to do mine. This problem may persist safely for a few months, but eventually will become annoying. It seems to be a common problem, and more so for the rear wheel bearing. I've never heard of it happening twice to the same car, so if you fix it once, you're probably good for life. Several racers replace their wheel bearing every year.
A broken emergency drum clip may cause a false diagnosis. Be careful when removing & replacing the rear rotors.
Oil woes
Many late 2000 thru 2001 Vette's burn a lot of oil when the engine is kept constantly over 4,000 rpm's. This is caused by ring flutter, which allows extra oil to seep past the oil control rings, but doesn't seem to cause any extra wear to the engine. Chevrolet has rebuilt and replaced engines for owners that complained about excessive oil consumption. Their policy is that while the engine isn't normally operated like that outside of racing, it is the owner's prerogative to drive around in second gear all the time if they want to. It is covered under the warranty.
The PCV system also has a tendency to suck oil back into the intake at high rpm's. It doesn't seem to cause any problems, other than a slight mess inside the intake manifold. The newer style PCV system can be installed, but this requires removing all the components in the top of the engine valley. Usually only racer's bother with the hassle. Several generations of PCV systems have had the problem, and at this time, December 2004, the PCV system still sucks oil into the intake.
The oil-sucking problem will cause carbon buildup in the cylinders. The dealership sells GM Top End Cleaner, and Napa sells SeaFoam. The Top End Cleaner is not available in some smog states like California. Run a tube from the bottle into the hole for the PCV system behind the throttle body on the passenger side. Start the car, then start slowly sucking the solution into the engine. Don’t go too fast or the engine could lockup. As soon as the solution is gone, stop the motor for >4 hours, but preferably 12 hours. Be aware that when the engine is restarted, there will be a LOT of smoke!
The oil-sucking can be prevented by installing a catch can. AMW and Greddy make catch cans, but a homebuilt catch can may be built using a Campbell-Hausfield air tool oil separator from most tool stores, including AutoZone. The AMW and Greddy cans are ~$100, but look great. The CH can is $15-25 for all the parts, and you can see how much oil is in it.
Overheating & burning smells
Even though the engine can heat up to 220, even 240 degrees Fahrenheit, this is normal. The radiator will keep the engine cool enough unless the radiator is blocked. Reprogramming the PCM can allow the fans to turn on earlier. If the fans also cool an aftermarket oil cooler, make sure the oil occasionally gets to 220 degrees to allow condensation and fuel to evaporate away. Fan settings and oil thermostats are two different ways to do this.
It's not uncommon for plastic bags to get sucked up under the front bumper, and cover the radiator, thus causing the car to truly overheat. If this happens, take a quick peek under the bumper, and remove anything under there. Sometimes bags get stuck to the exhaust pipes too, causing quite a stench as they burn away.
Locked steering column
All C5’s, particularly manual transmission C5’s, and early C6 steering columns have a tendency to lock and stay locked. Usually it can be unlocked once, but just once. Some owners claim that vigorously shaking the steering wheel can unlock the steering wheel. Dealer's are able to disable the locking mechanism with a modified locking plate. Currently this is the only real method to disable the locking mechanism. Basically the wheel will still try to lock, but there will be nothing for it to lock to. It’s like a door dead bolt with a slot cut into the door jamb. There is a $100 kit that disables the steering column lock, and can be installed easily, but enough car vibrations can cause the lock to fall into the locking plate, even while driving!
GM has a part (#88952428 or 88952428) that has a harness wiring jumper and different lock plate. Not sure what the difference in the kits are.
After reading a few posts, manual transmission C5’s & C6’s are still in danger, even if the lock is disabled. The lock can vibrate out over time and get trapped in the locking plate. Auto transmission cars that have undergone the recall and new auto’s will not have the locking plate at all, so they are safe. More information about COMPLETELY disabling the steering column lock will be forthcoming from other’s on the forum, and by my own personal project. Until then, here are a few links about the topic:
Corvette Forum - Column Lock Harness K Installation
Corvettemechanic - A4 non locking column plate --- must be a member
Corvette Forum - Column-lock again even with CLB!
Corvette Forum - Has anyone ELSE beat column lock?
Faulty gas gauge
If you have bad gas (phew!), the fuel sender can be affected by the high sulfur content in the fuel, and cause the gauge to read empty. They car will still operate normally, and the gas gauge will work again if you use better gas, and will usually start again when you restart the car. It's just better to use good gas. Some people have had luck with running fuel filter cleaners thru the gas tank. New fuel senders sometimes fixes this problem. This thread has a LOT of ideas about what could be causing the problems, how to avoid problems, and how to fix it. It also points out how the late C5 fuel tanks and crossover tube is different.
Noisy fuel pump
There are two fuel tanks, and two fuel pumps. One fuel pump continually pumps gas from the passenger side tank into the driver side tank, and is quiet. The main fuel pump is directly behind the drivers seat, and can be annoying loud, especially on early C5’s. It's normal, and not a sign of a failing fuel pump. Chevrolet does have a bulletin out instructing how to better insulate against the sound of the fuel pump. This is merely an annoyance. A newer, quieter pump can also be installed.
Extremely high oil pressure reading
The oil pressure sensor can fail, but it is still okay to drive. Turn the car off, but with the key in the “on” position and check the oil pressure gauge. It should read “0”. If the oil pressure sensor is bad, it will show a positive reading. The oil pressure sender is located behind the intake manifold, and will require moving the intake manifold. The sender costs about $40 and part # 12573107 or 12562230.
How-to
Suspension squeaking
In cold weather you may hear the suspension creak when you go over speed bumps. To fix this, clean (optional) and lubricate the sway bar bushings. The adjustable metal sway bar end links on Hotchkis and T1 bars can also create loud clicking sounds. Most adjustable end links are quiet initially, but wear out and get noisy over time. Greasing and protecting the end links from dirt may prevent wear.
Tough shifting
The shifter in manually shifted Corvette's takes a strong arm to get it into gear. You really have to make sure that the shifter is fully in 1st and Reverse, or it will pop out of gear when you let the clutch out. This is not the fault of the car, but rather the fault of the driver.
Manual transmissions -- Replacing the transmission fluid often helps shifting. Early transmissions have paper blocker ring that require Dexron III compatible (usually organic) fluid because some synthetics will destroy the paper blocker rings and subsequently the transmission. Later transmissions, and all rebuilt transmissions, have Kevlar/carbon fiber parts that allow the use of synthetic fluids. I believe the 98-00 transmissions have the paper blocker rings. The safe transmission fluids seem to be: GM Synchromesh PN #12345349, Honda ATF-Z1, Royal Purple Synchromax, Amsoil ATF, O’Reilly Dexron III ATF. The following transmission fluids may be unsafe for early transmissions: Redline D4 ATF, Mobil 1 ATF, Royal Purple Max ATF.
Related threads:
LS1.com - Ending the speculation: Blocker rings, who's had them fail?
LS1Tech.com - Ending the speculation: Blocker rings, who's had them fail?
Mobil 1 Synthetic ATF for a M6?
If it is especially tough to shift into 2nd or 4th gear, it's possible that the synchro's are worn out or the forks are bent. Do NOT force it into gear. Abuse creates and aggravates this problem. You can still drive, even quite well, without synchro's....or a clutch for that matter if you know how to rev match.
Some aftermarket shifters make it easier to make sure you're fully in gear, and prevent gear grinding, but they also vibrate, and require more effort to shift. The stock shifter has a tuned weight damper that changes the vibrations to a non-audible frequency. The shaking doesn’t annoy some people, and there are some fixes.
Leaky butt
The differential can leak from the side covers. The problem has to do with the design. The lip on the casing is not wide enough to create a proper seal with the cover. Resealing the covers can be successful, but many dealers do not use the correct sealant.
Inside/outside tire spinning
If one tire spins while turning, adjust the friction modifier ratio. Aftermarket gear fluid from Royal Purple, Amsoil and Redline do not require additional friction modifier. GM’s friction modifier is PN #12377916. Too much friction modifier and the inside tire will spin/skip/hop. Too little friction modifier and the outside tire will spin/skip/hop. -- Thanks Russ!
Tire hop
Tire hop during hard acceleration in cold weather is common, even if the same tires don’t hop in warmer weather. Tire rubber when viewed thru a microscope looks like a web. Normally parts of this web grabs onto objects on the ground and stretch until either the car moves forward, or the web breaks, resulting in tire spin. I believe in cold weather, the web is too stiff for either of these events to occur, so the tires hop. To find out more, read Racing & High Performance Tire: Using Tires to Tune for Grip and Balance. I haven’t read it, but if you do, please let me know if my guess is correct. I found a couple stories on Google about people curing wheel hop with stiffer bushings and/or (jounce) shocks.
Interior rattles
The visors may rattle when they are put up, but if you flip them down, the rattle goes away. Squeezing the mirror lid down seems to take care of it. Try glueing a piece of felt or velcro between the mirror and lid to see if that fixes it. Caravaggio also makes replacement leather visors, but they go for $400.
The stereo is Bose, and to go along with the historically crappy build quality of Bose products, Bose has graced the Corvette with Bose emblems on the door speaker covers that rattle when you play music with bass. A Bose system doesn't exist that puts out good bass, but the system still manages to rattle the emblems when playing Country, Hip Hop, or Techno at moderate volumes. Check this problem by having a passenger and yourself putting a finger on the emblems with music playing. Glue the emblems down to fix it.
If the roof isn't tightened down enough, it will rattle. There are some adjustment screws in the roof to make this adjustment.
Belt Chirping
During cold weather, the belt can chirp. Goodyear Gatorback belts from AutoZone don’t chirp.
Sticky Hatch
During cold weather, the hatch may pop up slowly, or not at all. Spray the latches with silicone grease until they come up properly. If the struts do not hold up the hatch, try lubing the strut bars.
1997: Service Bulletin: Hatch Will Not Pop Up When Activated in Cold Weather
Rocker failure
The needle bearings in the OEM rockers have been known to fail. Usually the problem is noticed with extra valvetrain noise and needle bearings stuck to a magnetic oil plug. Nasty Performance will rebuild OEM rockers with Harland Sharp bearings. This seems to be one of the better solutions since the stock rocker is very good at high rpms. Most aftermarket rockers are nose heavy and require grinding the heads and valve covers to fit. Currently Harland Sharp rockers are having problems with c-clip retainers falling off and causing problems on the way. I’ll be following this issue since I have a set of HS rockers on my shelf waiting for this issue to be resolved. Here are some links:
LS1Tech - EMERGENCY!! ROCKERS! Help ASAP!
LS1Tech - Harland Sharp Rocker Failure
LS1Tech - Install or not install HS rockers?
Other Information
Active Stability Control
This allows you to keep some control of the car even when you do really stupid stunts. It doesn't bend the laws of physics, but will keep the car pointed where you are steering; you may still slide off the road, but at least the car will be pointed in the direction you were steering! One of the sensors is located around the passenger seat, and needs to be considered when installing a racing bucket. If you move that sensor, Active Stability will not know how to balance the car, and can be very dangerous. Active Stability came out around '99.
Jacking
The C5 was the first car to use hydroformed frame rails. Hydroformed rails are quickly becoming a common platform for new cars, but not many shops are prepared to lift these vehicles. The C5 requires an adapter for regular jacks and lifts to fit the jacking points. Make your own adapters with a hockey puck (or two) with a 1 1/2" eye bolt screwed thru the center. Stick the eye bolt thru the slit in the jacking point, turn 90 degrees, place jack under adapter and jack away....if you can get the jack under the car. You may have to use ramps. The C5 is so low that most people make their own wooden ramps....rhino ramps are too steep.
Key Fobs
There are basically two different kinds of key fobs, and they are not compatible with each other.
97-00, but 00 does not have the Passive Lock feature
01-04
Spark plugs
The OEM platinum plugs, along with other plugs have had problems with the pucks falling off. I have a picture of missing pucks in this thread. This thread outlines some of the problems with using platinum, and a recommendation for using silver tipped plugs. Basically, of all spark plug tips, platinum is the worst conductor, copper is good, iridium is even better and silver is the best. Don’t take my word for it, do a little research, starting with this review. As for longevity, platinum, iridium and silver do have an advantage over copper, but plugs foul up after ~10K negating any difference corrosion would cause, and no plug will run well after 100K miles.
To make the spark plugs easier to change, get the Snap-On double-swivel sparkplug tool and remove the coil packs. Here’s all you need to know about sparkplug changes: Go!
________________________________________ _______________________
These problems, and many others, are addressed at the www.corvetteactioncenter.com in the Tech Center -> Knowledge Base.
While these problems do sound numerous and severe, just remember that JD Power considers this a very reliable car. If you buy a Corvette, consider yourself fortunate that there are many resources available to help you locate and correct problems.
Secrets of the C5
Copied from www.corvettemechanic.com
Quote:
● The little yellow “helper light” on the bottom of the rear-view mirror that illuminates the shifter area.
● That you can put your key in the driver’s door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
● That you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
● The little slotted cover on the dash behind the steering wheel is where the inside air temperature sensor is located.
● All of the option codes are in the glove box.
● Tire inflation recommended pressures are on the driver’s door.
● The thing that looks like a little LED near the DIC buttons is a light sensor.
● The thing that looks like a little LED near the defroster vent is a UV sensor for determining A/C usage to compensate for the heating effect of the sun.
● The build sheet is in the front re-bar.
● If you leave your turn signal on, in about 1 minute it will start to ding (loud enough to hear over the stereo) to let you know you have old timers disease.
● You can reset the oil life by pumping the gas pedal 3 times (but not with the engine running).
● Hold down the reset button while on one of the trip odometers and it changes that reading to the miles you’ve traveled since last starting the engine.
● Hold down the Active Handling button for 5 sec. to engage “Competitive Driving” on cars equipped with active handling (2000 and previous years must be stopped.)
● If you pull the seatbelts all the way out while you’re buckled in, they ratchet back in to hold you tighter into the seat. (then move the seat forward to make it extra snug -- Leafty)
● Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not flash. Your front turn signals will operate normally, however.
● The side-view mirrors can twist both forward and backward, decreasing the chance of damage if struck.
● There is a release opening with a flap to let air out of the car when the hatch is closed. It is located just above the driver side rear compartment behind the carpet and on the side of the car. Not that it really works well.
● Also you can ground your amp to a screw/bolt that holds the rear middle compartment to the frame.
● If you have a 6-speed car you can pop the trunk when the car is running by lifting the e-brake.
● There is a spot on the driver side just out of the middle compartment under the carpet for the lug nut key. You should have a compartment on the drivers & passenger’s side (in the trunk) and a center compartment. On the left (drivers) side of the center compartment, on the left side where the center cover fits, there is an ‘indent’ that holds the wheel lock key.
● If you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on.
● If you have the passive entry feature: If you lock the keys in the car, wait a few minutes and then shake the car. That will unlock the car.
● HUD has a shift light for the manuals.
● You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
● You can eject the cd from the in-dash player without turning on any power. Don’t even need key in the ignition.
● The cruise will disengage if you purposely make sharp side to side turns while cruising at say 60-80 mph.
● When the engine is shut off, you can get the odometer reading by turning on the parking lights.
● You can program setting #3 (both memory buttons at once) in the seat memory to run the seat back and steering wheel forward for getting in/out of the car with the engine running.
● If you hate DRLs you can pull the e-brake ONE click and they go off.
Power
First you need to know how your car is doing. A trip to the dyno can give you quick answers.
Tuning software can diagnose and tune your car. LS1Tech and HPTuners are two popular tuning packages. At some point in the future, both packages will be able to do scanning with incorporated wideband sensor support. At this time, December 2004, only HPTuners can do both.
Popular upgrades:
Cold air intakes: Vararam, Halltech, Blackwing, zip-tie
Intake manifolds: LS6, LS2, LSX, Wiend, sheetmetal
Cat-back exhausts: B&B, Borla, Z06 Ti, Corsa
Long tube headers: LG, Kooks, TPIS, Stainless Works, Breathless, Jet-Hot, GHL, QTP
Superchargers: ATI (go to A&A), Vortech, Magnacharger
Turbochargers
Stroke & bore
Head & cam packages: TEA, AFR, TSP, Patriot, Cartek
Tires: Kumho Ecsta MX, Nitto Extreme RII
Quote:
The convertible and coupe (it's really a targa) come with run-flat tires, with 17" wheels in the front, and 18" in the rear, with tire pressure sensors. The Z06 comes with non run-flat tire, but has a tire repair kit. Switching from run-flat tires to regular tires typically allows the C5 to ride softer, accelerate faster, and corner harder, but if you use the tire repair kit (goo) on wheels with the unobtainium tire pressure sensors, you'll destroy the sensors. No C5 has a spare tire. The best way to improve the handling of any car is usually thru the tires.
Aerodynamics, gearing and top speed
The hardtops and Z06 have shorter rear windows, are less aerodynamic, noisier, and weigh less than the standard C5 couple like mine. Even though the Z06 has more hp than standard C5’s, they have a lower top speed than manual Z51 C5 coupes. This is due to both aerodynamics and gearing. All C5’s top out at redline in 5th gear, so a taller 5th gear, or much shorter 6th gear, or taller redline is required to go faster. All else being equal, a Z51 coupe will still go faster than a Z06. Above 190 mph, air builds up under the front of the car. This can be solved with a vented hood like the ACP C5-R or MCM hoods.
Weight reduction
You can achieve substantial weight reduction with the following modifications, while still having a car that's very comfortable to drive. Most of these modifications will directly increase (and decrease in a few cases) the safety of the car, while safety is indirectly improved due to the better handling and limits of a lighter car. Fighter pilots say "speed is life". Acceleration, deceleration, and lateral acceleration are all forms of acceleration, and lighter cars accelerate better in each of these ways because the tires have less mass to control....thus a lighter car is a safer car. Lighter cars have better moments of inertia which allows them to turn in more easily and roll less. Lighter cars are also easier on the tires and gas.
All the stage weight estimates are typically wild butt guesses, but it makes it easy to see what is possible. The weight listings in the separate weight posting is MUCH more reliable.
Stage I: Streetable weight reduction mods
Non-popup headlights (~40 lbs)
Braking rotors with an aluminum hat, or titanium rotors (unproven on street cars) (~20-30 lbs)
Carbon fiber hood (~12 lbs)
Z06 (thinner) windshield and side windows (~5.7 lbs)
Non runflat tires (~20 lbs)
Slicks (~30 lbs)
Z06 wheels (~4 lbs est.)
Corsa titanium exhaust (~35 lbs)
Long tube headers (~20 lbs)
Halltech aluminum alternator & bracket (10 lbs)
Carbon fiber driveshaft (~2 lbs)
Newer torque tube
Less options [HUD, elec AC, Active Stability, seat/mirror/steering wheel memory, cd changer] (~50 lbs)
Less gasoline & wiper fluid (No wiper fluid=9lbs, 6 lbs for every gallon of gas in that 18 gallon tank....~81 lbs for autocrossing)
Remove cargo net
Remove targa top (~20 lbs)
Remove BCM’s
Remove C5 "appearance mods" - exhaust plates, doorsill covers, etc.
Remove fuel rail covers
Replace stock crank pulley with aluminum aftermarket pulley
Replace steel dampener with aluminum dampener
Replace stock targa top with lexan piece (coupes)
Replace water pump with electric water pump
Replace battery with smaller battery
Replace non-stressed fasteners with aluminum or titanium fasteners
Replace leaf springs with coil over shocks with titanium springs
Replace steel shifter with aluminum shifter and delrin or titanium shift ****
Remove all loose change, CD's, golf clubs, misc. items, from center console, hatch area, and glove box
Empty your pockets of extra change, PDA's, cell phones, keys, lead plates, or whatever other junk you lug around
Go on a diet =p
Stage II: Hardcore semi-streetable weight reduction mods
Aluminum flywheel (~10 lbs)
Lighter clutch like Exedy or Quartermaster (~10 lbs)
Racing buckets (40-50 lbs)
Remove tire repair kit (Z06)
Off
The following 77 users liked this post by David426:
1luckyVette (06-06-2018), 1Wizeguy (09-02-2017), 50BLKZ06 (03-08-2016), 8chhay (07-13-2017), 98Corvette! (11-09-2017), acboone@verizon.net (09-18-2016), Almosdef (03-21-2017), Azdadsun (08-05-2016), BarneyZ (05-02-2018), Barry6547 (03-02-2017), BATLSTAR (11-22-2017), black match box (11-19-2016), Blueleader (08-13-2017), Bob426 (01-26-2018), bryanbrooks13 (02-10-2018), C5 Art (08-21-2016), Chuckw99C5 (09-26-2016), Den's Vet (05-21-2016), doublenut9 (01-18-2020), DUPLICATE (01-12-2017), Elno Lewis (04-08-2022), Enderlin (04-29-2017), Eric02Vert (04-01-2016), Family Time (07-21-2017), Fast Cars & Horses (11-12-2015), Flightwriter (05-12-2018), FOGeologist (03-28-2018), Generdfelter (09-04-2017), glister (05-20-2016), H Watkins (09-25-2016), h00per (02-15-2017), HeyLoosie (04-28-2017), jayedwin98020 (08-11-2017), jimbo_22 (03-21-2016), jjbs7 (03-21-2016), JohnnyZee (05-10-2018), JrRifleCoach (08-04-2018), Jtum1970 (09-14-2017), Kimmers (03-13-2018), laurent_zo6 (11-10-2017), marc5 (06-06-2018), marebear (07-14-2018), Mayor111 (09-22-2017), MorganZilla (09-26-2019), Moto One (04-22-2018), motodog (11-14-2019), mralbe (12-10-2016), my01vette (01-06-2018), My1stC5 (06-16-2017), OCS1667 (08-29-2016), okiedan (04-10-2016), Opa'svette (05-19-2017), pajones321 (08-16-2016), plasticweld (01-28-2018), rbr54 (10-17-2016), rbucchino (06-29-2017), rwd2k1c5 (07-24-2016), Saltywheels (02-14-2017), seeswell (05-01-2017), SG Lou (02-23-2017), skeeter131 (01-07-2017), SkyeVue (08-03-2017), Staylor63 (10-12-2017), StudebakerJoe (02-03-2018), Texastri (09-02-2016), thunder1951 (08-17-2016), Tillrodsfly49 (04-04-2016), tmirisola (01-19-2016), Tulsaeasyrider (04-23-2017), twynia (12-03-2017), v8ess10 (07-11-2016), Vette-High (11-26-2018), WetMountainMan (01-05-2018), WhiteKnuckleRide (10-13-2016), wmupaprmkr (12-30-2020), woolfmandave (06-07-2017), ZERRY 316 (01-23-2017) and 72 others liked this post. (Show less...)
Old 12-04-2005, 10:05 AM
rws.1
rws.1's Avatar
You are correct . It should be a must read for new C5 owners.
I think most if it is in a sticky at the top of C5 General called weights, measures etc.
But is is a great post and a timley read
The following 2 users liked this post by rws.1:
FasNuff (02-15-2017), My1stC5 (06-16-2017)
Old 12-04-2005, 12:44 PM
Mudlizard
Mudlizard's Avatar
I am a new owner and I found this to be some great info. Thanks for posting it. I printed it all out for reference. 15 pages, but worth it.
Thanks again, I REALLY have to get that stock battery and platinum plugs out of there!!
Old 12-04-2005, 12:53 PM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Thanks for reposting this. However, by cut and pasting, the original links are lost and there are some good links in the thread.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 12-04-2005, 01:02 PM
84bronzevette
84bronzevette's Avatar
although I have replaced clutches and wheel bearings on C5s for friends, I know little about them. We just added a nice 99 vert to our stable and this compilation of info is very informative and much appreciated.
Thanks; Scott
Old 12-04-2005, 05:09 PM
RichS23
RichS23's Avatar
What is the best way to fix the "Seat Rock" problem?
joeyo27 (08-05-2016)
Old 12-04-2005, 06:21 PM
2KFRC5
2KFRC5's Avatar
One correction - Optima is not a gel-type. It's a liquid lead-acid in Absorbent Glass Mat, in a sealed case.
willy g (05-16-2017)
Old 12-04-2005, 06:39 PM
game on
game on's Avatar
David426,
Thanks for sharing this information. Thanks also the original poster!
Great forum, members willing to share and try to help another.
Old 12-04-2005, 06:40 PM
David426
David426's Avatar
There was an excellent thread on this with step by step instructions and pictures. I saw it about a year ago. Try a search. Unfortunatly, these threads are only kept in the archives for so long. It may not be there now. Try reposting a new thread with this topic. Another member may have it saved somewhere or remember who posted it originally.. Found it http://robbs.js-x.com/ken/vette1/
Old 12-04-2005, 07:10 PM
Mike Mercury
Mike Mercury's Avatar
that's good info... but some of it is personal preference (there's no right/wrong)
for example :
Seat choice
I can't fit in those restricting little sport seats. I intentionally ordered my 2002 without them. And I don't road race.
so for others like me... "Don't get the sport seats"
Old 12-04-2005, 07:14 PM
j3studio
Support Corvetteforum!
j3studio's Avatar
Cruise-In V Veteran
St. Jude Donor '06
Great read!
Old 12-04-2005, 07:30 PM
edensknight
edensknight's Avatar
Always a helpful read.
Old 12-04-2005, 07:37 PM
David426
David426's Avatar
The original thread with hyperlinks included is indeed posted in the "C5 GENERAL" Forum at the very top under Sticky: Weights measurements, etc.. as rws.1 stated early in this post. I really think the Moderators should move that thread under the Tech section and rename it something else. Common Problems and Fixes would be an appropriate title. More people would see/use this thread if it were replaced and renamed. Just my opinion. I like to see things straight foward without digging or searching to much. Here is the better link for lazy folks http://forums.corvetteforum.com/show...7&forum_id=103
Old 12-04-2005, 07:41 PM
hybridmoments
hybridmoments's Avatar
Thank you...i got a lot of useful info from this..will print
Old 12-04-2005, 07:55 PM
PHVette
PHVette's Avatar
St. Jude Donor '06
Thanks!!!! Great info
Old 12-04-2005, 09:31 PM
Lovin It!!! - C5
Lovin It!!! - C5's Avatar
Lots of great info here!
Old 12-04-2005, 09:40 PM
Dark-Knight
Dark-Knight's Avatar
Awesome!
To One of the Best Threads ever posted Newbies must read
Old 12-09-2005, 07:16 AM
Billdog350
Billdog350's Avatar
The brake link in the orig thread above didn't work, but this is from the same company and does work: http://www.stoptech.com/tech_info/wp...akedisk.shtml#
A very informative thread for C5 owners...and the brake thread is good for ANYONE who wants to increase brake life and reduce vibration.
Old 12-09-2005, 04:53 PM
nmbsun
nmbsun's Avatar
Thanks for the post!
Old 12-09-2005, 11:09 PM
Paras
Paras's Avatar
Good stuff!
Quick Reply: One of the Best Threads ever posted Newbies must read
