XM Radio
XM Radio
I just saw a comment about a code to use when subscribing to the XM service that gets you a good rate. Does anyone have any other details on this as I probably will get it after the trail period expires.
xm radio
Call 800 845 3072 or 682 4114 , use code MYP1 and looks like you can get it for $5.00 a month for an additional 12 months.$60.00 per year. Good Luck. Save the Wave.>George
Originally Posted by jim213
Try "ZWINBACK" You should be able to get it for $77.00 for the year.
I checked my charge card the next day to to make sure the charge was correct and it was.
I had heard of the code to get the service for $60.00 but I lost track of the information. You should try that code first and maybe you'll get the service for $60.00 instead of $77.00.
Finally, if the person you're talking to isn't making it happen, just hang up and call back a little later. You'll get a different person I'm sure.
fyi -
I just activated my xmradio using the ZWINBACK promo code for $77/year. XM reset my 3-month trial period (which I had only used for less than a week), and set up the 1-year at $77 to start on February 5, 2006.
I first tried activating using the MYP1 code to try to get $60/year, but the rep told me that code had expired and suggested I call the dealer for an alternate code.
I then gave her the ZWINBACK code, she said that was still active and it had replaced the MYP1 code. Either code was a great deal of the normal price, so I'm happy.
Even though I still have 2 months left on my trial period, I called in to XM (about 10 minutes ago) and asked for the ZWINBACK promotional code. The guy there knew just what I was asking for, $77 for an additional 12 months and access to internet broadcast as well. This is a much better deal than what was listed on the GM site. I'm very pleased and would suggest that if you want to renew, do it while this is available!
